Aerocool Readies RS-4 Mid-Tower Gaming Case
"Chassis maker Aerocool has come through with another one of its gaming cases today; this time around it is the RS-4 Mid-Tower chassis."
Search News
Chassis maker Aerocool has come through with another one of its gaming cases today; this time around it is the RS-4 Mid-Tower chassis. Featuring some exclusive and eye-catching design elements, the RS-4 has been designed in a black/red color scheme.
Aerocool has given its RS-4 gaming chassis all the features that can be expected from a case of its class. The black and red case has been structured using 0.6mm SECC steel, which gives it a sleek and classy yet sturdy appearance. The front of the case features four exposed 5.25-inch drive bays, which are added to by two HDD cages on the inside of the case. One of the two HDD cages is removable if extra space is required within.
The manufacturer has designed the RS-4 such that users can insert and remove their optical disk drives and HDDs without any tools. The top of the case has two USB 2.0 ports, eSATA, audio and mic jacks – all part of a special I/O panel. There is also a 58-in-1 card reader, seven expansion slots, and a built-in handle for lifting and carrying the case.
Aerocool has equipped the case with two 140mm LED-lit fans – one each on the front and the top respectively. The 1,500 RPM fans provide strong cooling for the entire assembly and they do it without emitting anything more than 30 dBA of sound. The fan speeds can even be controlled using the specially provided fan controller.
For those who prefer liquid cooling for their rigs, the RS-4 has a couple of pre-drilled holes in the back that are perfect for water cooling tubes. The best part about the chassis is that despite so many system elements, the case itself only measures 475 (H) x 200 (W) x 475 (D) mm in dimensions.
Enthusiasts and gamers can expect to get their hands on the RS-4 within the next few days and will have to shell out €79.90 for this gaming chassis.
Discuss in our Forums
Aerocool RS-4 Mid-Tower Gaming Case
«Prev 1 Next»
07-01-2011, 21:12:02
killablade
Well, at 800Mhz it passed memtest with 0 errors ;)
08-01-2011, 05:42:04
lasher
iexplorer.exe is the main exe of internet explorer.
is that same exe in the system 32?
if so it could be a virus.( trojan )
Looks like something may have attached a virus to your system folder possibly. Notice your running utorrent so possibly picked an nasty up from there ( im sure its used legitimately ofc )
09-01-2011, 21:56:31
killablade
All legitimate ofcourse :D
On Mon 10-1-2011 2:40:54 your computer crashed
This was likely caused by the following module: ntoskrnl.exe
Bugcheck code: 0x4E (0x9A, 0xB0C1B, 0x2, 0x0)
Error: PFN_LIST_CORRUPT
Dump file: C:\Windows\Minidump\011011-20482-01.dmp
file path: C:\Windows\system32\ntoskrnl.exe
product: Microsoft® Windows® Operating System
company: Microsoft Corporation
description: NT Kernel & System
The crash took place in a standard Microsoft module. Your system configuration may be incorrect, possibly the culprit is in another driver on your system which cannot be identified at this time.
And right after that another one. I've had the pc folding for hours with no errors, then I stop folding, go and browse the web for a while and it crashes?
On Mon 10-1-2011 2:52:32 your computer crashed
Bugcheck code: 0x50 (0xFFFFFA829A970818, 0x0, 0xFFFFF80003393314, 0x5)
Error: PAGE_FAULT_IN_NONPAGED_AREA
Dump file: C:\Windows\Minidump\011011-19812-01.dmp
I'm growing quite tired of this. Thinking of reinstalling windows. Got a backup drive nowadays so I can make a backup of all the important stuff.
Anything else that could cause this? HDD failure maybe? Any way to check it?
10-01-2011, 03:48:16
lasher
Browsing the web you say,
That will be it then. The error ( or virus whatever ) lies there.
Have you ran Malaware bytes?
What extensions are in internet explorer?
10-01-2011, 07:03:26
killablade
Well I don't actually use internet explorer. I always use firefox.
I haven't run Malaware bytes, will do that now.
But the thing is, it has also happened to me while watching videos. I'm not sure if I had firefox open while doing that though.
And if I don't shut my PC down after a bsod, the bsod will occur much quicker (sometimes even when I'm not fully into Windows yet.)
Edit: So I ran a quick malwarebytes scan.
Code:
Malwarebytes' Anti-Malware 1.50.1.1100
www.malwarebytes.org
Database version: 5494
Windows 6.1.7600
Internet Explorer 8.0.7600.16385
10-1-2011 13:08:44
mbam-log-2011-01-10 (13-08-44).txt
Scan type: Quick scan
Objects scanned: 157731
Time elapsed: 3 minute(s), 48 second(s)
Memory Processes Infected: 0
Memory Modules Infected: 0
Registry Keys Infected: 0
Registry Values Infected: 6
Registry Data Items Infected: 0
Folders Infected: 0
Files Infected: 1
(No malicious items detected)
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\RunServices\Recycler (Trojan.Clicker) -> Value: Recycler -> Quarantined and deleted successfully.
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\RunServicesOnce\Recycler (Trojan.Clicker) -> Value: Recycler -> Quarantined and deleted successfully.
HKEY_CURRENT_USER\SOFTWARE\Microsoft\Windows\CurrentVersion\RunServices\Recycler (Trojan.Clicker) -> Value: Recycler -> Quarantined and deleted successfully.
HKEY_CURRENT_USER\SOFTWARE\Microsoft\Windows\CurrentVersion\RunServicesOnce\Recycler (Trojan.Clicker) -> Value: Recycler -> Quarantined and deleted successfully.
HKEY_CURRENT_USER\SOFTWARE\Microsoft\Windows\CurrentVersion\Policies\Explorer\Run\Recycler (Trojan.Clicker) -> Value: Recycler -> Quarantined and deleted successfully.
HKEY_CURRENT_USER\Software\Microsoft\Windows NT\CurrentVersion\Windows\load\Recycler (Trojan.Agent) -> Value: Recycler -> Quarantined and deleted successfully.
Folders Infected:
Files Infected:
c:\Users\Arjen\AppData\Local\Temp\iexplorer.exe (Trojan.Clicker) -> Quarantined and deleted successfully.
10-01-2011, 08:01:29
benj3
haha that should be it then if iexplorer was infected :P good luck from now on :D
10-01-2011, 16:02:26
Typhoon10
What hardware specs you got?
10-01-2011, 16:05:00
benj3
He has
CPU Make: Intel GPU Make:
Nvidia CPU: Intel Core 2 Quad Q8200 2.33 ghz @ 3 Ghz
Motherboard: MSI P45 Platinum
Graphics Card: Asus ENGTX470 730/1460/2000
Memory: Crucial Ballistix Tracer 4GB DDR2 860Mhz CL5-5-5-15 2T
Cooling: Prolimatech Mega Shadow (w/ Scythe push/pull)
Power Supply: Corsair TX750W Sound Card: Creative X-Fi Xtreme Audio
Monitor: Samsung SyncMaster P2450H 24" 2MS Full HD
Sposedly :P
10-01-2011, 17:04:07
killablade
He has
Sposedly :P
Correctemundoo, although my cpu is now running at 2,8 instead of 3.
Hard drives are 2 Spinny F3's in RAID0 and a Western Digital Caviar Blue 640GB
19-01-2011, 20:28:35
Isaac Miell
I haven't resized it so you can actually read the text.
I get that popup everytime I boot up my pc.
Looks like a virus to me mate. Have you got a boot disk that you can read/write NTFS from?
If so, I'd use it to delete that file and then remove it from any startup listings (msconfig/autoruns).
