Antec reveals their new P8 Chassis
ANTEC reveals their new P8 Chassis
Today Antec has revealed their new P8 chassis, which offers support for an ATX motherboard, up to a 360mm water cooling radiator at the front and sports two tempered glass side panels while coming with an attractive price tag of £69.99 in the UK.
This chassis sports two 3.5/2.5-inch drive bays under the case’s bottom PSU shroud as well as four dedicated 2.5-inch drive slots, giving this chassis enough space to suit the storage requirements of most PC builders.
In terms of water cooling, this chassis supports up to a 360mm or a 280mm radiator at the front, a 120mm radiator at the rear and has limited support for a 240mm radiator at the top (Thin radiators). Alternatively, the top of the case can be used to support 3x120mm fans or dual 140mm fans.
At the top of the case, there are two USB 3.0 connections as well as standard HD audio jacks, alongside standard power and reset switches. At the front of the chassis, there is also a white glowing Antec logo.
This new chassis is now available to pre-order in the UK from select retailers. The MSRP for this chassis is £69.99 in the UK and €79.99 in the EU including VAT.
You can join the discussion on Antec’s new P8 chassis on the OC3D Forums.
Â
