ARCTIC COOLING Release The Turbo Module
"ARCTIC COOLING has introduced the Turbo Module – An ultimate cooling add-on for Accelero S1 / S2"
Published: 25th June 2007 | Source: ARCTIC COOLING |
AC Product Launch: Turbo Module
Pfäffikon/ Switzerland, 25.6.2007. The Swiss cooling solution provider – ARCTIC COOLING has introduced a special Turbo Module, an ultimate cooling add-on for enthusiast gamers. The Turbo Module increases the potential power of Accelero S1 and S2 with enhanced cooling performance under extreme quiet operation.
Turbo Module helps boost up the GPU and memory overclockability, squeezing more graphic performance than ever before. Featuring dual high performance low noise fans, Turbo Module was designed to work together with Accelero S1 and Accelero S2 – the widely adopted and award winning passive cooler for numerous ATI and nVIDIA graphic cards. The optimized fan speed dramatically reduces the temperature of GPU, RAM and Voltage Regulator. Turbo Module especially reinforces the PC case overall ventilation, and its clip-on design allows for easy installation.
| “Finally it’s here, an absolute fantastic cooling weapon for 3D gamers,” said Patrick Chung, marketing manager of ARCTIC COOLING. “Turbo Module integrates with the Accelero S1 or S2, they’re the ultimate cooling combo that every enthusiasts must have.” |
Turbo Module is an add-on accessory for Accelero S1 and Accelero S2. As with the other ARCTIC COOLING products, Turbo Module users can enjoy a 6 year limited warranty. Turbo Module will be available by the beginning of July 2007. The MSRP is USD 11.90 and Euro 8.90 (excl VAT).
Accelero S1 is widely compatible with ATI (Radeon X1950, X1900, X1800) and nVIDIA (GeForce 7950, 7900, 7800, 6800) graphic cards. Accelero S2 is widely compatible with ATI (Radeon X1650, X1600, X1550, X1300, X1050, X850, X800, X700, X600, X550, X300 and 9XXX series) and nVIDIA (GeForce 8500, 7600, 7300, 6600, FX 5950, FX 5900, FX 5700 (Ultra), FX 5600, FX 5500, FX 5200, 4 TI and MX series) graphic cards.
More product details here
I had some of the short GPU EK barbs on the Apogee and it leaked.
The GT is the exact same fitting so...
So should use the plastic ones?
OR just put 2 seals on it.
Did you?
Rob
Did you?
Rob
I bought some XSPC barbs and used them :D
Ok, ill use the plastic ones for now, and then when i make a new order ill add some to it.
Rob
Rob
Ye the plastic ones are fine, if a little hard to get the tubing off of
Thanks
Rob
