Cooler Master gives us new low profile cooler.
"Cooler Master gives us a low profile CPU cooler! Showing that size does not always matter, with a 92mm Blade Master PWM that can hit 2800 rpm if needed."
Search News
  • Scrolling Image
  • Scrolling Image
  • Scrolling Image
  • Scrolling Image
  • Scrolling Image
Cooler Master brings out the new Vortex Plus, a low profile CPU cooler with four 6mm direct contact heat-pipes for maximum heat conductivity, it also has a 92mm Blade Master PWM fan, ideal for the mini-ITX motherboards as well as slim casings.
Even with its tiny size the Vortex Plus manages to give great cooling power featuring a Blade Master 92mm balance PWM fan, this can be as quiet as 17dBA at 800 rpm or you can boost it up all the way to 2800 rpm if needed. The 6mm heat-pipes maximizes the heat conductivity which is quickly removed by thin bladed aluminium heatsink.
The Vortex Plus comes with many mounting accessories that enables it to fit onto all the current motherboards and CPU’s. It has its own custom push-pin solution for Intel motherboards, making it easy to add and remove the Vortex Plus, it also has does not have to be screwed in place like many other custom cooling solutions.
Specifications can be found below:
CPU Socket
Intel Socket LGA1366 / 1156 / 775
AMD Socket AM3/AM2/940/939/754
CPU Support
Intel LGA 1366 / 1156 / 775 Socket CPU
- Core™ i7 Extreme
- Core™ i7
- Core™ i5
- Core™ i3
- Core™2 Extreme / Quad / Duo
- Pentium
- Celeron
AMD AM3 / AM2 / 940 / 939 / 754 Socket CPU
- Phenom™ II X4 / X3 / X2
- Phenom™ X4 / X3
- Athlon™ II X4 / X3 / X2
- Athlon™ X2
- Athlon™
- Sempron™
(For the latest CPU support information,please visit our website.)
116 x 100 x 84 mm (4.6 x 3.9 x 3.3 inch)
445g (1 lbs)
Heat Sink Material
Aluminum fins + 4 heatpipes
Fan Dimension
92 x 92 x 25 mm (3.6 x 3.6 x 1 inch)
Fan Speed
800 – 2800 RPM (PWM)
Fan Airflow
15.7 – 54.8 CFM
Fan Air Pressure
0.35-4.27 mm H2O
Bearing Type
Long life sleeve bearing
Fan Life Expectancy
40,000 hours
Fan Noise Level (dB-A)
17 – 35 dBA
12 VDC
Current Ampere
0.26A Max.
Power Consumption
3.12W Max.
The new Vortex Plus will be available from the end of June/beginning of July and will have an MSRP of around £23. Not a bad buy at all.
Discuss in our forums.
«Prev 1 Next»
30-03-2010, 05:15:31
The Cassini spacecraft in orbit around Saturn has caught an interesting new view of the tiny moon Mimas.
30-03-2010, 05:42:12
I Hunta x
oh awsome....... i wonder how long it will be till mayhem finds this lol
02-04-2010, 15:20:02
Wacka wacka wacka
02-04-2010, 18:52:46
i saw it on the bbc news a few days ago i giggled a bit.
will be some retro boffin thinking what the hell is pacman doing there.
