EK releases monoblock for ASUS Maximus VIII Impact motherboard
EK Water Blocks, Ljubljana based premium liquid cooling gear manufacturer, is proud to release another ASUS® MAXIMUS VIII motherboard monoblock – EK-FB ASUS M8I Monoblock. It’s compatible with ASUS MAXIMUS VIII Impact motherboard.
EK-FB ASUS M8I Monoblock is a complete all-in-one (CPU and motherboard) liquid cooling solution for Intel LGA-1151 socket Skylake CPU and the ASUS MAXIMUS VIII Impact motherboard.
Designed and engineered in cooperation with ASUS®, this monoblock uses award winning EK-Supremacy EVO cooling engine to ensure best possible CPU cooling. This water block directly cools Intel LGA-1151 socket type CPU and power regulation (MOSFET) module as water flows directly over all critical areas. It is a very high flow water block that can be easily used with the system using weaker water pumps.
EK releases monoblock for ASUS Maximus VIII Impact motherboard  EK releases monoblock for ASUS Maximus VIII Impact motherboard
Base of the monoblock is made of nickel-plated electrolytic copper while the top is made of quality POM Acetal or acrylic glass material, depending on the variant.
EK-FB ASUS M8I monoblock is made in Slovenia, Europe and are readily available for purchase through EK Webshop and Partner Reseller Network. In the table below you can find MSR prices with VAT included.
You can join the discussion on EK’s Maximus VIII Impact Monoblock on the OC3D Forums.
Â
