EK showcase their upcoming Gigabyte Z270X-Gaming 7 monoblock
Â
EK have showcased their upcoming Gigabyte Z270X-Gaming 7 monoblock, which will cool both the motherboard’s  VRMs and CPU core with a single water block.Â
Â
This monoblock design is not only more aesthetically pleasing than most multi-block offerings but it also simplifies hose/tubing management, with only a single input and output holes for coolant instead of the having to deal with inputs and outputs for several separate motherboard and CPU water blocks.Â
Â
EK will be revealing more information on this monoblock at the start of next week, where the company will also reveal pricing information.Â
Â
Â
 Â
Â
We have also had confirmation that EK has plans to introduce similar monoblock designs for future high-end AM4 motherboards, finally allowing AMD users to use a CPU+Motherboard monoblock. Before now these monoblock designs have been exclusive to Intel users.Â
Â
You can join the discussion on EK’s Z270X Gaming motherboard monoblock on the OC3D Forums.Â
Â
