New ENlight Micro ATX Mini Tower
80 PLUS power supplies make better use of energy, being both more reliable AND cooler than standard power supplies. 80 PLUS power supplies are 20% more efficient; 80% efficiency at 20%, 50% and 100% utilization. 80 PLUS power supplies also increase reliability by 40%, reduce stress on semiconductor components in the PSU and will reduce energy costs for the user.
ENlight PM1501 Specifications:
Case Type: Micro ATX Mini Tower with plastic foot stand
Main Board size: Micro ATX (9.6″x9.6″)
Drive Bays: 1 x 5.25″, 1 x 3.5″ and 2 x 3.25″(hidden) All Tool-less
Expansion Slot 4 x Low Profile
Dimensions 94mm x 350 mm x 341.6 mm(w/o bezel)
Safety Certificate Meets CE, FCC, UL
Chassis 0.6mm SGCC
Currently available at authorised distributors and resellers, the PM1501 Micro ATX Tower retails at around £45 inc. VAT from; www.entaonline.co.uk, www.northamber.com, www.rd-uk.co.uk and more.
Power Supply Features:
Measures 175mm Long, 85mm Wide and 70mm High
SS-300TFX Active PFC
Specification Compliance TFX12V V2.1
Pentium 4 ready with P4 connectors
Forward converter circuit
High efficiency and reliability
Low ripple and noise
Super low noise fan control
Short circuit protection on all outputs
Over voltage and Over power protection
100% hi-pot test
100% burn in, high temperature cycled on/off
Power Supply Specifications:
Input Frequency50/60 Hz
In-rush current, cold start100A Max
Hold up time, full load12ms. Typical
Efficiency; at normal input voltage>80%
Dielectric withstand, input to frame/ground1800VAC, 1Sec.
Dielectric withstand, input to output1800VAC, 1Sec
Line Regulation ‘+/- 1% typical
Load Regulation ‘+/- 5% typical
Cross Regulation ‘+/- 5% typical
Ripple/noise 1%
MTBF, full load @ 25 degrees C amb. Excluding the DC Fan >100k hrs
Power Factor Correction; Active PFC 99% typical
Compliance; CUL, TUV, CB CE, FCC and C-tick
Discuss in our forums
