NZXT release the Whisper
"NZXT Whisper Sets a New Standard for Silent Computing Performance "
Search News
  • Scrolling Image
NZXT Whisper sets a new standard for silent computing performance OC3D Official Press Release
NZXT, a company built on realizing the dreams of gamers worldwide, is proud to announce the Whisper, a gaming chassis designed for the enthusiast who isn’t willing to sacrifice silence for performance. The Whisper features the following cutting-edge features…
NZXT Whisper* Silent Performance – 10mm noise dampening foam pads both side panels and the top panel, rubber grommets reduce vibration noise on the Hard Drives, and a padded PSU holder dramatically reduce acoustic levels within the chassis
* Maximum Expandability - Space for 9 hard drives and a total of six 5.25” bays with ample room for large expansion cards
* Simple Installation – Pre-drilled wire management system makes it easy to route your cables and the screwless installation means you won’t be constantly reaching for your tools
* Advanced Cooling – Whisper includes 4 fans( 1 x 120mm Blue LED Intake, 1 x 120mm Black Rear Exhaust, and 2 x 80mm Rear Exhaust). Bottom mounted PSU separates the heat given off by the PSU and motherboard
“Whisper is a really exciting option for the gamer who wants to maximize both computing performance and silent operation” said Johnny Hou, Chief Designer at NZXT. “NZXT’s advanced noise dampening technology combined with the many expansion options make Whisper a superior building block for any PC gaming rig.”
Retailing for $139.99, the new Whisper case will be available in September.
For more information on the NZXT Whisper, please visit www.nzxt.com/products/whisper.
Discuss the NZXT Whisper in our forum
«Prev 1 Next»
22-08-2008, 18:16:48
Hassan
Ok
I know a few people who have killed their motherboard because of the bios update failure.
Well we all know that the bios is in the small little PLCC chip on the motherboard, but have we all considered pulling that chip out and re-programming with them small little programmers out in the market.
Have a look here
Well I know that some people here @ :oc3d: know this, but I was bored and decided to research this further.
They are kinda expensive, but we all should have this I think considering the BIOS is the most annoying thing to update.
The whole point of this thread was just to let y'all know about this.
23-08-2008, 06:42:32
Zoot
Most of those chips are soldered to the motherboard these days so replacing them would be impossible and even if you could and you wanted to program it yourself you'd have to find out the how to map the electrical connections of EEPROM chip using a programming language such as ABEL with one of those programmers. It would be a lot more trouble than it's worth IMO.
I've bricked a laptop in the past with a BIOS update failure but luckily I got the motherboard replaced under warranty.
I've also had to use the BIOS recovery feature twice on my 4 year old home build: (AMD Sempron 2600+, Asus K8V-MX, 512MB DDR, XFX 6200 AGP, XP and Ubuntu)
Apparently the EZ flash utility was somewhat buggy in the first few BIOSes released for that board or so I was lead to believe. Floppies are also pretty prone to error. Flashing off a USB key is much more efficient (CRC is a Godsend! :D)
All I can say is thank God for BIOS recovery features. :)
Anyway what I'm basically saying is that the BIOS should always fall into the "If it ain't broke don't fix it" class.
23-08-2008, 10:24:41
Pyr0
with an SPI flasher/programmer and using the SPI headers included on many new mobos, there's no need to remove any bios chips, you just flash em in place
i still have an old p5k3 dlx board i need to send off for reflashing, just haven't got round to it...
