Phanteks Announces ASUS Aura Ready RGB LED Adapter for RGB LED strips
Â
Phanteks has announced their new ASUS Aura Ready RGB LED Adapter for their RGB LED strips, allowing those using motherboards with the ASUS Aura RGB LED header to control their Phanteks Case RGB LEDs and led strips.Â
This RGB LED adapter will be releasing next month for the price of â¬2.90, giving users a cheap and easy way to make ASUS’ RGB LED motherboard header comparable with ALL phantek’s RGB LED strips.Â
Â
Â
This connector will also be compatible with all future motherboards that contain a pin (12V G R B) RGB header, so hopefully other motherboard manufacturers will use this standard for future RGB LED integrated motherboards.
Â
Â
The RGB LED Adapter is currently compatible with Phanteks’ Enthoo Luxe, Mini XL, P400, more upcoming models will follow. The adapter will also be compatible with integrated RGB motherboards with the 4-pin RGB headers.
Â
You can join the discussion on Phantek’s ASUS Aura compatible RGB LED header on the OC3D Forums.Â
Â
