Silverstone has released Tempered glass versions of their RL06 series cases
Silverstone has announced new versions of their Redline RL06 series of ATX cases, which come with tempered glass side panel windows. These two new versions will be available in black/red and white/black colour options, with both standard single rear 120 fan options and a Pro version that includes three 120mm LED fans at the front of the chassis.
This chassis will be made primarily made from steel and plastic, weighing in at 6KG and comes with support for GPUs that are up to 348mm in length and CPU coolers that are up to 158mm tall. This chassis will also support a 240mm radiator at the front and top of the case and PSUs that are up to 200mm in length.
Silverstone’s RV06 cases all feature a PSU shroud and support for three 3.5-inch drive bays and two 2.5-inch drive bays. This chassis offers no support for 5.25-inch drive bays, which means that users of this chassis cannot instal optical drives.
At the front of the chassis, the RV06 also supports two USB 3,0 ports and dual USB 2.0 ports.
These cases will be available for $90 for the RL06-G (Glass) and $100 for the RL06-GP (Glass Pro). Pricing will be the same for both colour options.
You can join the discussion on Silverstone’s new Tempered Glass RL06 cases on the OC3D Forums.
Â
