Thermaltake Unwraps External ProWater PW880i LCS Cooler
"Cooling solutions manufacturer Thermaltake recently unveiled the ProWater PW880i LCS as a complete water cooling solution for the PC."
Published: 6th July 2009 | Source: Thermaltake |
Cooling solutions manufacturer Thermaltake recently added an external cooling solution to its range of ProWater PC Coolers. According to the manufacturer, the ProWater PW880i LCS is a complete water cooling solution for the PC.Most Recent Comments
that should leave room for a monster gfx card too :)
thanks
I would go for a decent 500watt PSU for the head room.
Such a system in it's current form will require require a quality 450W PSU with solid voltage rails. In the name of leaving headroom for anything that may consume rediculous amounts of power, I'd be looking at PSU's rated at 600W and higher. Make sure that any PSU that you buy is on 80PLUS' tested and approved list.
:worship: verbatim.
thanks
