EVGA SRX Motherboard First Look
EVGA SR-X Motherboard First Look
So we finally have our EVGA SR-X sample at the OC3D office, it was until it arrived we realised just how much work we have to do with this motherboard. To get ready for the initial motherboard review we have 2 different sets of CPU's to test along side our usual 7970 bench rig GPU, but then just because we obviously have so much time on our hands in a separate review we are also going to be testing it with a GTX690.... Maybe then another one for some Quad SLI OverKILL3D madness!
So upon realising we have a mountain of testing to climb we though all you tech junkies would like an aperitif to get your juices flowing before the main course!
Performance
 Based on Intel C606 chipset
 Supports Dual QPI Socket 2011 Intel Xeon E5 Processors
Memory
 12 x 240-pin DIMM sockets
 Quad Channel DDR3
 Maximum of 96GB of DDR3 1600MHz+
Expansion Slot
 0
Storage I/O
 0 x UltraDMA133
 4 x Serial ATA 300MB/sec (4x Internal) with support for RAID 0, RAID1, RAID 0+1, RAID5, RAID10 and JBOD
 4 x Serial ATA 600MB/sec (2x Internal + 2x E-SATA) with support for RAID 0 and RAID 1
Integrated Peripherals
 8 Channel High Definition
 2 x 10/100/1000
Multi I/O
 1 x PS2 Keyboard
 6 x USB3.0 ports
 10 x USB2.0 ports
 Audio connector (Line-in, Line-out, MIC)
 FireWire 1394B (1 external)
Form Factor
 HPTX Form Factor
 Length: 13.6in - 345.4mm
 Width: 15in - 381mm
Key Features
  •      NVIDIA SLI Technology
  •      USB 2.0 Support
  •      Serial ATA II
  •      6 - Phase Power Design
  •      On-Board Clear CMOS Button
  •      On-Board Power Button with Integrated Power Light
  •      On-Board Reset Button with Integrated HDD Activity Light
  •      On-Board Diagnostics LED Readout
  •      2-Way SLI® Support
  •      3-Way SLI® Support
  •      Windows XP™ Support
  •      Windows Vista / Windows 7™ Support
  •      DDR3 Support
  •      Dual-Channel Support
  •      300% more gold content in the CPU socket
  •      Supports EVGA's EVbot
  •      4-Way SLI® Support
  •      SATA III 6GB/s
  •      USB 3.0 Support
  •      100% POSCAP Capacitors
  •      PCI Express 3.0 Ready
First Look Video
So we hope this has wet your appetite be sure to keep an eye on the main reviews section in a week or so for the first of the reviews! You can discuss your thoughts on the board in the OC3D Forums.
«Prev 1 Next»
13-06-2012, 11:25:52
dipzy
13-06-2012, 16:22:52
wassupdoc
Haha, YES! actually guessed it right on your FB Quote
13-06-2012, 17:52:18
SieB
I don't like the look of it, it's an awesome board performance wise and for what it is, I just don't like the way it looks.Quote
13-06-2012, 21:12:23
Excalabur50
I can't belive they really put the battery under a heat sink Quote
13-06-2012, 21:28:35
SparkleDJackson
I think it looks crap. Its the giant finny heatsink that turns me off and seeing the battery underneath just looks dumb it needs a well designed waterblock and processors that actually overclock to be worth the investmentQuote
