AOC launches their 40-inch C4008VU8 curved 4K 10-bit display
Â
AOC has now launched their new 40-inch C4008VU8 curved 4K 10-bit display, coming with an MVA panel and support for 85% of the NTSC colour gamut.Â
Â
Sadly this display does not come with support for variable refresh rate technologies like FreeSync or G-Sync, giving this display a refresh rate of 60Hz. Combine this with this display’s 5ms response time and we have a display that is not well suited to gaming, though it’s large size, high resolution and 10-bit colour support will make it a great option for professional use.Â
Â
 Â
Â
Right now this display is available for purchase at Amazon US for $850 in limited quantities, making it one of the most affordable 4K 40-inch 10-bit PC displays available.Â
Â
AOC’s C4008VFU8 will come with the following specifications:
- Viewable Screen Size:Â 40-inch
- Panel Type:Â VA
- Aspect Ratio:Â 16:9
- Brightness: 300 cd/m²
- Refresh Rate:Â 60Hz
- Contrast Ratio (dcr):Â 20M:1
- Response Time:Â 5ms
- Max Resolution: [email protected]//
- Color Depth:Â 1.07B
- View Angle (degrees) (H x V):Â Horizontal: 178 Degrees (CR>10) Vertical: 178 Degrees (CR>10)
- Cabinet Color:Â White/Silver
- Adjustability Tilt: -5°±1.5°~+13.5±1.5°
- Inputs:Â VGA, HDMI 1.4 (MHL), HDMI 2.0 (MHL), 2 x Display Port 1.2, 4 x USB 3.0 (1 x Fast Charging)
Â
AOC lists this display as having an MSRP of $899. Â Â
Â
You can join the discussion on AOC’s 40-inch C4008VU8 curved 4K 10-bit PC display on the OC3D Forums.Â
Â
