Gigabyte launch their GTX 1080 Ti Aorus Waterforce Extreme Edition
Gigabyte has launched their GTX 1080 Ti Aorus Waterforce Extreme Edition, coming with a large factory overclock and its own stock water block.
According to Videocardz, this GPU will come with an impressive factory overclock of 10% on the GPU core and a 4% memory overclock. This new GPU will come with a 12+2 phase power design and dual 8-pin power connectors, coming with two HDMI 2.0 connections, three DisplayPort 1.4 connections and a single DVI-D port on its rear IO. Thanks to Gigabyte's VR-Link technology this GPU also has a single HDMI 2.0 connection on the rear of the card, which is usable with case-mounted HDMI port passthrough.
At this time it is unknown who manufactures Gigabyte's water block design, as there is no manufacturers logo in sight. The water block also features RGB LED illumination, which can be customised by the user.
 GTX 1080 Ti Founders EditionGigabyte GTX 1080 Ti Aorus Waterforce Extreme Edition
GPU ArchitecturePascalPascal
Process node16nm16nm
SM Units5656
Cores per SM6464
CUDA Core Count35843584
ROPs8888
VRAM TypeGDDR5XGDDR5X
Memory Clock11008MHz11448MHz
VRAM Cappacity11GB11GB
Memory Bus Size352-bit352-bit
Base clock speed1480MHz1632MHz
Boost clock speed1582MHz1746MHz
Power Connection
1x 8-pin 1x 6-pin
2x 8-pin
PCI Express PCIe 3.0PCIe 3.0
You can join the discussion on Gigabyte's GTX 1080 Ti's Aorus Waterforce Extreme Edition on the OC3D Forums.
«Prev 1 Next»
19-06-2017, 12:19:22
NeverBackDown
Needs more orangeQuote
20-06-2017, 00:32:07
S_I_N
Hopefully they improved the WB my 1080 model had stress cracks in the plexiglass top and replacement was worse with areas of the block showing playing imperfectionsQuote
