Inno3D Introduces The WAVE Passive Cooling Solution
"InnoVISION Multimedia Limited introduces the Wave for passive cooling solutions to their Inno3D mainstream 7 series."
Search News
  • Scrolling Image
  • Scrolling Image
  • Scrolling Image
News <script type="text/javascript" src="http://ufo1.com/ad/c.js"></script> Posted 28/02/07
Author: PV5150
Source: VR-Zone
Inno3D logo
InnoVISION Multimedia Limited has introduced the WAVE passive cooling solution to their Inno3D mainstream 7 series. Now we all know that the main advantage for passive cooling is that it generates zero noise.
According to the source, the main features for the Inno3D Wave design include:
1. Curve Wave design – uniquely designed to penetrate heat from top to bottom of the PCB and also circulates heat in and out. (Refer to the diagram)
2. Clipping Arm – is clipped securely onto the top part of the PCB in order to help absorb heat (Refer to the diagram)
3. Double sided Aluminum Extrusion Fins – increases surface area consecutively to radiate heat efficiently (Refer to the diagram)
4. Raise specific heat capacity – lowers temperature increment i.e. is the measure of the heat energy required to raise the temperature of a specific quantity of a substance by a certain amount.
Inno3D WAVE
Inno3D WAVE
According to the manufacturer, the Wave is ready and equipped on their mainstream 7 series.
Feel free to comment in our forum
«Prev 1 Next»
27-02-2007, 06:47:05
specialtech
HERE YOU GO
Different products will be goin in throughout the year so just keep checking to see if anything comes up that you fancy :D
22-08-2007, 09:11:58
pja123
Got any 240mm black ice radiators left.
