PowerColor Adds PCS+ to Radeon HD6870 Card
"AMD graphics card specialist TUL Corporation today upgraded their PowerColor PCS+ series of graphics card with the addition of the PCS+ HD6870 card. "
Search News
AMD graphics card specialist TUL Corporation today upgraded their PowerColor PCS+ series of graphics card with the addition of the PCS+ HD6870 card. According to the manufacturer, the card is factory overclocked and outfitted with some serious cooling power to allow it to be pushed further.
The PCS series from PowerColor has been highly successful due to its top-notch cooling solution plus extraordinary overclocking capabilities. Now TUL has brought these same capabilities to the latest HD6870 cards. The GPU comes overclocked out of the box at 940MHz core speed, with the memory set to run at 1100MHz. The 256-bit, 1GB DDR5 memory ensures there is no lag in graphics processing even in the most demanding of applications and games.
The combination is quite capable of boosting data transmission rates all the way to 4.4Gbps. Such heavy data transfers of course need rock-solid cooling, which has been taken care of with the PowerColor Professional Cooling Solution. The PCS+ HD6870 comes equipped with a 92mm cooling fan that creates terrific airflow. The 3 pure copper heat pipes channelize this airflow over all components to provide extraordinary cooling with total heat dissipation via the copper base.
Compared to the reference card, the PCS+ solution keeps the PowerColor GPU cooler by as much as 15%, leaving lot of room for overclocking and tweaking. So while the card is factory overclocked, enthusiasts will still be able to draw more out of their cards to maximize performance.
TUL Corporation has also bundled Call of Duty: Modern Warfare 2 game with the package to sweeten the deal further for enthusiasts. All eyes are now on the pricing for the card, which should hopefully be announced soon with the availability.
Discuss in our Forums
PowerColor PCS+ Radeon HD6870 Card
«Prev 1 Next»
04-11-2010, 10:42:56
hmmblah
Just a heads up (saw this at FM)...
Use promo code EMCZZYR24 for 10% off any GPU at newegg.
That makes a Gigabyte GTX470 $206 after MIR. I seriously want to order this and do SLI.
04-11-2010, 10:59:07
hmmblah
OK, I'm ordering another 470. Should I get the cheap version or for $40 more get the "Ultra Durable" version that supposedly has better components?
The reviewed model GV-N470UD-13I is a special version that incorporated more durable component which GIGABYTE called it Ultra Durable VGA (UDV). Gigabyte’s UDV board employs high quality components including 2 oz Copper PCB, 1st tier memory, Japanese solid capacitors, ferrite core chokes and lower RDS (on) MOSFET, resulting in 5% - 10% lower GPU temperature, 10%~30% better overclocking capability and 10%~30% less power switching loss.
Has me convinced to get the UD version.
04-11-2010, 11:03:13
AMDFTW
UD for reliability fella
abd uts worth it
04-11-2010, 11:36:22
hmmblah
Ordered. Wife is going to murder me.
04-11-2010, 11:37:36
SnW
Just tel her it was my idea :D
nice buddy i would take it , it is going to Fold as well ? B)
04-11-2010, 11:39:25
hmmblah
It will be doing more folding than gaming, that's for sure :lol:.
Do you still have to disable SLI when folding and mess with adapters?
04-11-2010, 11:41:48
SnW
Not sure about the SLI thing IIRC you still need to disable it,
i have never used adapters? you mean dummy plugs right ? :wub:
04-11-2010, 11:48:11
hmmblah
Yeah, that's what I meant, the dummy plugs.
04-11-2010, 11:54:12
SnW
Never used them always the -gpu 0 flag(s) and the correct mutiple screen setup :)
04-11-2010, 12:02:41
AlienALX
Wicked thanks for that. My friend is currently wanting one of these
http://www.newegg.com/Product/Product.aspx?Item=N82E16814261073&cm_re=palit_470-_-14-261-073-_-Product
Which will no doubt poo on the stock one for cooling.
