Overclock3D's Weekly Review Roundup - 18/05/08
"A variety of stuff, seems to be a good a week for news."
Published: 18th May 2008 | Source: OC3D |
Every week Overclock3D's news mailbox is spammed full of content from partner sites around the globe. Even with a dedicated team of 50 news posters we just cant keep up! So here's a round-up of the best bits we've received over the past week:
Here is a common question. Do you splurge and get the shiny new model? Or hang back and look for something realistic for the current market?. The DFI Dark Series makes that question easy by featuring top of the line chipsets, high-end LanParty styling, and excellent BIOS features. All at a fraction of the cost, in a way this is what enthusiast hardware should be, all business and no fluff! - Ninjalane
Sunbeam has come out with a nice tool that solves the mystery of how to handle multiple formats of hard drives. The SATA/IDE to USB 2.0 Adapter can use 2.5" and 3.5" SATA and IDE drives and easily converts them to a USB 2.0 interface. Its compact size, flexibility and low price make it a nice addition to a tool bag or work bench. - techPowerUp
To be fair, I’m still in two minds about the GeForce 9800 GTX. And even though BFG Tech has gone above and beyond the call of duty here, I still don’t think it’s enough for me to change my mind about this particular card in Nvidia’s line-up. You see, the standard cards are still on the expensive side compared to the GeForce 8800 GTX and GeForce 8800 GTS 512, while BFG Tech’s GeForce 9800 GTX OCX is priced at such a point that it’s no longer competing against only products in Nvidia’s line-up, but also against the Radeon HD 3870 X2. And over time, it seems like the 3870 X2’s drivers have improved a bit and it’s now becoming a more rounded purchase when you compare it to something like the card we’ve looked at here today. - bit-tech
recently looked at the ThermoLab Micro and found it to be an energy efficient processor-only cooler that was designed for small enclosures. Today we are going to look at the ThermoLab Nano, an even smaller cooler made for the same type of application; extremely small enclosures and cases. Before you start to yawn I will go ahead and say upfront that the Nano performed better than the Micro, even though it is a smaller cooler and fan. What is really attention getting is the size of the cooler and the custom applications that modders will be able to use with it. - TweakTown
It's been a while since last reviewing a computer chassis from NZXT (November 2006 with the NZXT Zero), but today we have our hands on NZXT's newest chassis, the Tempest. NZXT describes this mid-tower steel chassis as being the "airflow king" with four 120mm fans and two 140mm fans, in addition to being ready for a dual radiator setup for water-cooling. NZXT has also taken this case a step further by accommodating eight hard drive mounts and room for an extended ATX motherboard, all inside this case that measures in at 211 x 512 x 562 mm. We first viewed the Tempest back at CES 2008, and in this review we'll tell you what we think of this newest NZXT creation. - Phoronix
When the budget is tight and you have to have a quality free flowing case for that next gaming PC you are building, who are you going to give your money to? Once again, Cooler Master has a new release for under $70 that looks to be jam packed with the features you are looking for. - Techgage
The OCZ Vendetta 2 heatsink features three large copper heatpipes that make direct contact with the top of the processor. This approach takes advantage of the superior heat conducting capabilities of 8mm diameter heat pipes to efficiently move heat from the processor to the cooling fins, without any intermediary steps. The technique is called Heatpipe Direct Touch, and as you've seen by the Top 5 Heatsinks chart... it's a winner. - Frostytech
The Everglide DKTBoard is an incredibly sturdy input device, intended for the hard core gamer. A very compact size, partial aluminum construction and backlight make it perfect for LAN parties. - techPowerUp
I was a bit surprised that Asus asked us to review their *flagship budget* -- it's weird just writing that -- 8600 GT TOP. It's new SKU for a card closing in on its end of life; the model being about a year old now. Just the same, with a hundred-dollar price tag, it's definitely got an audience, no matter what cards there are competing against it, or what cards have been released since. And it's a pretty highly-regarded card; go on any hardware forum and there's a dozen NVIDIA people extolling the virtues of the 8600 GTs when it comes to budget gaming. Now, I'm not saying that they're all wrong, but it is worth finding out if new drivers and some moderate factory overclocking can put value on an otherwise dated video card. - TheTechLounge
Yet another good week of news, enjoy and discuss on our Forums.
Hi there,
The Big Water 760i would have problems just cooling the CPU correctly to be totaly honest.
To cool these components you wuld be looking at a custom kit or a pre-watercooled case like this for example:
XSPC Edge Watercooled Case
Pascal, thats a link to the case only :D
The Edge kit looks very good indeed, with good head room for upgrading to.
Hi and thanks, case looks fine , what about custom cooling kit , here i have prepared a list tell me what did i miss. and one more ,I have choosed XSPC pump for high flow , to put everything in one loop , is it possible?, i didnt chose NB sinks couse i will have Asus striker extreme 2 witch already have one pre-installed and i have one fan controler witch i can use for this setup.Any suggestions ?I will be very greatfull for any support given.
pump-XSPC Dual 750 Bay Reservoir Pump
radiator-ThermoChill PA120.3
cpu block-EK Supreme CPU Block
gpu block-EK-FC9800 GX2 SLI
tubes-3x1/2" Blue/UV Blue High Flex Hose
fans-3xZaward Clear 120mm Quiet Golf Fan,
tubing clips and liquid and etc;]....
and about the case you think that ThermalTake Armor+ cant support this cooling setas a internal one?
planning to spend on this kit about 180£ max, maybe your suggestion about custom kit( i`m really newbie to water cooling so please tell me what parts i must buy i dont want to miss something ;]). Thanks and have a nice day
