SilverStone Nightjar 500W Fanless PSU Available Soon!
"The SilverStone Nightjar series of power supplies is the ideal solution for system builders who want a completely silent PSU that doesn't sacrifice on performance or quality."
Published: 2nd August 2011 | Source: SilverStone |
The SilverStone Nightjar series of power supplies is the choice of builders who want a completely silent PSU that doesn't sacrifice on performance or quality. The latest model in the Nightjar series is the brand new ST50NF 500W unit due for release by the end of the month.
Providing 500W with up to 38A on the +12V rail, as well as 80 PLUS Silver efficiency this fanless passive power supply pushes what is possible without the active airflow and noise a fan provides. As with other fanless PSUs the Nightjar 500W ST50NF uses its casing as a giant heatsink, which transfers the heat away from the critical components into the air and case without the use of a fan.
We can expect to see it in retailers within the next few weeks. For more information please see the SilverStone Tech ST50NF Product Page.
You can discuss this in our forums.
OK guys, a little update, as my overclocking situation has changed slightly.
For the CPU- 4.4GHz constant, at 1.336V max
For the RAM- 1866MHz, timings 10-9-10-24-1.35V
For the GPU- 900MHz core, 4400MHz memory, 1.1V
_______________________________________________________________________________________________________________________________________________________________________________________
OK, here are the Far Cry 2 benches:
Settings: Demo(Ranch Small), 1920x1080 (120Hz), D3D10, Fixed Time Step(No), Disable Artificial Intelligence(No), Full Screen, Anti-Aliasing(8x), VSync(No), Overall Quality(Custom), Vegetation(Very High), Shading(Ultra High), Terrain(Ultra High), Geometry(Ultra High), Post FX(High), Texture(Ultra High), Shadow(Ultra High), Ambient(High), Hdr(Yes), Bloom(Yes), Fire(Very High), Physics(Very High), RealTrees(Very High)
Before: Average Framerate: 111.56, Max. Framerate: 169.37, Min. Framerate: 81.57
After: Average Framerate: 122.73, Max. Framerate: 190.86, Min. Framerate: 90.50
And the Crysis 2 benches:
Using Adrenaline Crysis 2 Benchmark Tool, Settings:
Quality (Ultra), Resolution (1080p), AA (4x), Map (Variable), Runs (1), API (DX11), Edge AA (Laplace Edge Detection), Hi-res Textures (Yes)
Before:
Map 1---Times Square---5000 samples, Min FPS 3.2, Avg FPS 54.8
Map 2---Central Park---5000 samples, Min FPS 6.0, Avg FPS 47.9
Map 3---Downtown---4609 samples, Min FPS 15.1, Avg FPS 50.8
After:
Map 1---Times Square---5000 samples, Min FPS 4.5, Avg 60.9
Map 2---Central Park---5000 samples, Min FPS 6.9, Avg 53.9
Map 3---Downtown---4609 samples, Min FPS 2.4, Avg 56.2
So this is a CPU overclock of 19% over the previous Turbo level.
And a GPU overclock of 12.5% and 7.5% over the previous Core and Memory clocks respectively.
In Far Cry 2, this has led to a 10% increase in the average framerate.
In Crysis 2, this has led to an 11%/12.5%/11% increase in the average framerate, respective of Maps 1/2/3.
Will be doing the Dirt3 one a bit later, got some Napoleon Total War to play
Which by the way gives my graphics card a harder time than Crysis2 can. Especially with all the mods
In terms of analysis, I am not thinking the CPU makes much of a difference, nor should it.
Its also very interesting that a Core overclock of 12.5% on the GPU is leading to around 11% increase in framerates.
Taken from my project log.
[IMG]http://i949.photobucket.com/albums/ad335/SIEJO/Crysis2Tool.jpg[/IMG]
Those temps look too high to me, might be an idea to contact EVGA. Make sure you haven't left something on the card in an important place or anything, like a piece of plastic.
Is that BF2 or Bad Company 2? If its BF2 then alarm bells should be ringing. What are temps in more demanding games?
Also try turning on V-Sync, maybe your card is rendering stupid amounts of frames and creating unneccessary heat...
I had that (except the memory was at 2048) at 1.025V out of the box, so it might be OK. You gotta test it though, for example at stock volts Crysis 2 was crashing.
Oh, and no matter what I do, the benchmark tool is crashing (you know the bit where the splash screen stretches out). The game itself works perfectly so I doubt its overclock related.
