ASUS ROG Vulcan ANC Headset Review
The Echelon headset we recently reviewed was a complete joy, being way better than we'd expected and competitively priced too. For a standard ASUS headset it had great performance. So when we were asked to review the Republic of Gamers Vulcan ANC headset you can imagine that the thought of a product sufficiently high-end for ASUS to apply their much vaunted ROG branding to had us salivating.
The ANC part of the name stands for Active Noise Cancellation. This is a rare feature on headsets of any description, much less gaming ones. It attempts to provide a negative hum waveform so that any positive ones nearby, such as from your case fans or similar hardware, are cancelled out and your ears are free from that annoying drone.
So armed with our trusty ASUS Phoebus sound card and a wealth of audio options to put the Vulcan ANC through its paces, let's crack on.
ASUS ROG Vulcan ANC Headset Review    ASUS ROG Vulcan ANC Headset Review
The specifications of any headset don't give many clues away as to what you can expect. 32 Ohm impedance is par for the course and 40mm drivers, whilst not the largest we've seen, are around the average too. Of special note is the light weight of the Vulcan ANC, which is especially good when you consider the noise cancelling hardware and battery needed to run it.
Driver Diameter: 40mm
Frequency Response Headphone: 10Hz ~ 20000 Hz
Impedance: 32 Ohm
Noise Cancelling :
Active: Maximum > 15 dB. 85 % ambient noise (fans etc)
Passive: Maximum > 30 dB
Dimensions: 21x18x7cm
Weight: 325 g
Battery Life: Up to 40 Hours
Cable:
3.5mm stereo plug (microphone)
3.5mm stereo plug (headphones)
Contents:
Vulcan ANC Headset
Carrying case
User Guide
«Prev 1 2 3 4 Next»
25-09-2013, 07:13:22
tinytomlogan
http://www.overclock3d.net/gfx/artic...113452231l.JPG
Today we're looking at an active noise cancelling headset from ASUS, the ROG Vulcan ANC.
Continue ReadingQuote
25-09-2013, 07:38:17
ShaunB-91
Interesting read, deffinelty one to consider when I buy one for my rig. £80 seems reasonable too.Quote
25-09-2013, 07:38:37
Michaeljcox24
Interesting review, I had a pair of Vulcan ANC's and I took them back to the shop. Presentation wise they are the mutts nuts, but I didn't think much of the sound quality at all.Quote
25-09-2013, 07:40:51
ShaunB-91
Did you use them for gaming? Could you comment on the quality in-game such as BF3? I'm looking for something that gives a punch behind the guns, and vehicles.Quote
25-09-2013, 07:49:34
tinytomlogan
Bry did say turn off the noise cancelling......Quote
25-09-2013, 08:03:45
SPS
I could have sworn these had already been reviewed when they came out..?
Also these are extremely heavy to wear over a long period of time.Quote
25-09-2013, 08:12:35
SuB
You mean your beats aren't doing it for you? Quote
25-09-2013, 08:14:04
ShaunB-91
Lol I doubt they'd be suitable for gaming. They are a bit irritating today actually, compressing my head!Quote
25-09-2013, 08:15:59
SuB
Hate to say I told you so :P
Tbh, headsets are all well and good, but not much touches proper headphones. I'm sure james will say DT770 but I still maintain BF3 (and in a week BF4) sounds utterly superb on AKG's Quote
25-09-2013, 08:20:47
ShaunB-91
The Mixrs are quite uncomfortable, it only takes 15 minutes before your ears are in need of a break. Super super tight fit. They work for running, I've tried it once but not something I'd like to use them for. They also block out all noise so if I run after work through the woods it's quiet and not very safe, but at the weekend when there are runners, cyclists and dog walkers it's okay.
But looking for some that are good for BF before I buy some in-ears for running. My pockets just aren't deep enough. BF4 is so close as well. :|
Edit: What's the price tag on these AKG's?Quote
25-09-2013, 08:23:48
B0GiE
I have the Vulcans and a pair of AKG K451's.
Clarity is much better on the AKG's. ASUS Vulcan's are distincly average imo.Quote
25-09-2013, 08:44:23
SuB
http://www.amazon.co.uk/s/ref=nb_sb_...rds=AKG%20K702
I have the K702's, I'd advise a Xonar Essence to go with them for best results Quote
25-09-2013, 08:46:00
ShaunB-91
Oh shizzle, they aren't cheap! Quote
25-09-2013, 08:53:17
Michaeljcox24
Yeah even with the noise cancelling off I didn't rate them. It was probably more a case of I wanted some high end head phones, and not a headset - mic combo.
In the end I went to one of those hi fi shops and spent 150 on a pair of quality Gredo's.
For the average joe though (assuming you have fairly small ears) these would be fine.Quote
25-09-2013, 08:55:52
SuB
You get what you pay for
The other option is DT770's which are cheaper but are closed back. My research/preference led me to the AKG's. BUT we're totally derailing in here now. This could be discussed elsewhere if necessary.Quote
25-09-2013, 17:22:49
critical
v-moda do a mad cable that integrates a boom mic called the BoomPro. Turns your headphones into a headset. No more sub par gaming experiences.
http://v-moda.com/boompro-microphone/Quote
26-09-2013, 04:01:28
SuB
Or y'know Antlion modmic...Quote
26-09-2013, 14:09:29
critical
That would work but it also gives you another cable to deal with..Quote
28-09-2013, 02:58:56
Xploited Titan
No fan of noise cancelling technology.
And I have heard enough complaints from people using such headphones, bout the tiring white noise and the feeling their ears are always "under pressure".
They should find something else imho.Quote
