Microlab Solo 8C Speakers Review
Microlab are mostly famed for their speakers. They have a huge array covering everything from little stereo sets to some monster setups. We recently looked at their 5.1 setup which would be more likely to be found as part of a computer arrangement than in your living room.
Today we’re going to be reviewing a pair of speakers that you will probably attach to your television instead, the Solo 8C. A monster pair of speakers with enough power to be suitable for deafening the neighbours, coupled with enough inputs to ensure that even the most obscure of arrangements is catered for. With wooden cabinets to support solid audio and minimise distortion, the Microlab Solo 8C promises to be a solution to all of your audio requirements.
So without further ado, let’s see what the Solo 8C has to offer.
Technical Specifications
Connectivity is definitely the star of the show with the Microlab Solo 8C speakers. Not only in the amount of options available to you, but the complete set of cables that is provided in the packaging to ensure you aren’t left scurrying to your local audio emporium. The speakers themselves, with 60W RMS each, are certainly powerful enough to fill any room. One of the big benefits to a full-size set of speakers is the ability to have a separate speaker for each band for optimum audio fidelity.
Amplifier
Output power: 120 Watt
Distribution: 60 Watt x 2 RMS
Harmonic distortion: 0.3% 1 Watt 1kHz
Frequency range: 50 Hz – 20 kHz
Signal/Noise ratio: > 80 dB
Separation: > 60 dB
Speakers
Tweeter driver: 1”
Tweeter impedance: 4 Ohm
Midrange driver: 4”
Midrange impedance: 4 Ohm
Woofer driver: 6.5”
Woofer impedance: 4 Ohm
Interfaces
Output: Binding posts
Input: 2RCAs x 2 (AUX and PC), TOSLINK, Coaxial RCA
Wireless: infrared remote control
Package contents
SOLO8C x 2 pcs
3.5mm – 2RCA cable
Speaker interconnect cable
2RCA – 2RCA cable
Optical TOSLINK cable
Coaxial RCA cable
Remote control
User manual
Dimensions
Product: 212 (W) x 460 (H) x 250 (D)mm
Product weight: 16.4 kg
