Qpad QH-90 Headset Review
The Swedish company Qpad are probably a new name to most of us here. As their company name would attest they began producing mousepads at first. Now, twenty years later, they have a good range of peripherals all designed for the pro-gaming community.
Today we're going to be taking a look at their premium headset model, the QH-90. Available in both white and black it's actually taking a different slant than the majority of headsets we've come across. Rather than being all about thumping bass, the tagline for the QH-90 is "Brings HiFi to the game". This should give you a nice indication of what we can expect from the Qpad QH-90.
With a very tight marketplace dominated by the SteelSeries Siberia at the mid-range and the Corsair Vengeance Wireless at the higher-end, is the quality of the QH-90 sufficient to challenge the well established brands in the market?
The first thing that strikes you when looking at the specifications for the Qpad QH-90 is the size of the drivers. Most headsets run 40mm drivers, so to see 53mm ones definitely shows the determination to have good audio quality across the whole of the audio spectrum. Utilising 3.5mm jacks means that the QH-90 should be compatible with almost anything you care to plug it into.
Transducer type: Dynamic 53mm
Operating principle: Closed
Frequency response: 15Hz-25KHz
Nominal impedance: 60 Ω per system
Nominal SPL: 98±3dB
T.H.D: < 2%
Power handling capacity: 150mW
Sound coupling to the ear: Circumaural
Ambient noise attenuation: approx.20 dBA
Headband pressure: 5 N
Weight with microphone and cable: 350g
Cable length and type:  1m + 2m extension + 10cm iphone
Connection: Mini stereo jack plug(3.5mm)
Transducer type: Condenser (back electret)
Operating principle: Pressure gradient
Polar Pattern: Cardioid
Power supply: AB powering
Supply voltage: 2V
Current consumption: Max 0.5 mA
Nominal impedance: ≤2.2 kΩ ± 30%
Open circuit voltage at f = 1 kHz 20 mV / Pa
Frequency response: 100 - 12,000 Hz
T.H.D: 2% at f = 1 kHz
Max. SPL: 105dB SPL (THD ≤ 1.0% at 1KHz)
Microphone output: -39±3dB
Dimensions: 6*5mm
Length mic boom: 150mm(include gooseneck)
Capsule diameter: Ø6mm
«Prev 1 2 3 Next»
18-04-2013, 08:47:26
I think they look really lush, I wonder do they sit over the ears or on them as I can't wear headphones that sit on my ears.Quote
18-04-2013, 09:20:07
Yeah I have to agree the quality looks top notch.
Nice product and thanks for the review chaps Quote
18-04-2013, 13:39:54
Excalabur, i have a pair of these and for me they sit over my ears not on them. So unless you have big ears i don't think it should be a problem.Quote
18-04-2013, 19:17:28
Awesome thanks for that it seems so hard to get ones that go over rather than on, now to see if I can get them here in Aus.Quote
22-04-2013, 10:58:13
Those really look like BeyerdynamicsQuote
