Roccat Kulo Gaming Headset Review
In the four years that Roccat have been producing gaming hardware they’ve stormed the market with some of the highest quality peripherals around. Here at OC3D we’ve reviewed most of the Roccat range and found them all to be worthy of a place on any shortlist.
A while ago we reviewed the 5.1 Roccat Kave and found them to be outstanding. Today we’re taking a look at the second Roccat Headset to come across our review desk, the Roccat Kulo Stereo Gaming Headset.
This is available in two flavours, one with a USB virtual 7.1 soundcard and one without. We have the one without on test today as it enables us to have a regular baseline to test against.
LAN Gaming has always been a big audience for gaming peripherals and with more and more events being held around the globe it’s to this market that the Kulo has been targeted.
Technical Specifications
A look at the specifications for the Kulo show a good response from both the headset and the microphone. A decent length cable with an in-line volume control aids usability and that light weight should ensure comfort and ease of portability.
HEADSET
Frequency range: 20~20.000 Hz
Impedance: 50 Ω ± 15 %
Sensitivity at 1kHz: 102 dB ± 3 dB
Max. output: 80mW
Driver diameter: 40mm
Driver magnets: Neodymium
Driver membrane: Mylar®
MICROPHONE
Frequency range: 70~20,000Hz
Sensitivity: -47 dB ± 3 dB
Signal-to-noise ratio: 50dB
Impedance: 2,2 KΩ
Directivity: Bi-directional
Type: Noise filtering
GENERAL
Weight: 178g (excl. cable)
Connection: 2 x 3.5mm
Cable length:
2.5m
