Aerocool Strike-X Air Review
We've looked at quite a few Aerocool items here at OC3D and can say that we have noticed something of a theme developing with regards to their styling.  Lets just say that they're not exactly subtle.  Now that's not a criticism, it's merely a statement of fact, and I would hazard a guess, a direct result of a marketing strategy.  Let me explain.  With the most avid users and therefor buyers of all things PC and gaming being men between 18-25 it stands to reason that along with those that prefer sleek black understated cases, a good proportion of this demographic will like the aggressive bold styling that is the hall mark of Aerocool products, and in particular the "Strike" range.  Oh yes, this case comes as part of range, and I don't mean just the other cases in the Strike range, you can also get PSUs, Mice, fan controllers and before long even speakers.
So lets look a bit more closely at the Strike-X Air.  Having established it's an open frame design it's probably best you understand just how big this case is.  It's not tall as most cases are being only 340mm in height, but what it lacks in height it makes up for in other areas.  With a width accross the front of 612mm and a depth of 535mm you'd best be sure you've got room on your desk for it.  For the rest of the vital statistics lets turn our attention to the technical specification.
Material: SECC 0.7mm Steel
Motherboard: Micro ATX, ATX, XL-ATX
Dimensions: 340mm (H), 613mm (W), 535mm (D)
Drive Bays: 3x5.25" (Exposed), 3x3.5"HDD or 2.5"SSD
Expansion bays: 10
Max GPU Length 330mm
Max CPU Cooler height 230mm
Ftont I/O:  1xUSB3, 3xUSB2, 2HD Audio
«Prev 1 2 3 4 5 6 Next»
23-07-2012, 14:50:25
Hey, can i get a Corsair H100 or a Phanteks PH TC14PE whit a closed cover? Or can a H100 be installed?Quote
24-07-2012, 00:24:25
thanks GDUB... when TTL introduced it at the show, it was a different something, just couldnt
wrap my head around it. but now, that you've shed a light on it, (or as well as you could be
cause of how large it was) it is different in a different way.
it doesn't look portible for a LAN case. it supports water cooling (grommets in the bulkhead) but
where to mount a radiator(s)? again, great review. told me what i need to know and how my
open benches are important without worrying about the top blowing off! LOL...
24-07-2012, 07:56:07
@ Danzle. If you read the review you'll see I do mention that there is 230mm of space with the lid in the horizontal position so yes the 171mm tall phantek wil fit. With the lid fully closed however I doubt it. H100 wise, there are mounting holes on the bar that runs above the PCI rear I?O area for attaching a rad, however if you went for a 120.2 like the H100 you're going to have to think hard about where your PCI cables exit etc so's you don't go and obstruct them with the rad.
@ Airdeano. Please see above re rad mounting holes and page 2 para5 of the review.Quote
20-11-2012, 00:03:17
Almost PERFECT! Except for this one : it might slower you SATA III 6Gbit/s transfer rate. also don't know either it using SATA Revision 3.1 or not.. wasting on my SSD Quote
20-11-2012, 06:20:41
I decited to go for this one (in regards to my Folding/Bench table thread),
seems to have all the things i need and pretty cheap as well,
Thanks for the review Gary Wain (bit late)
Greetings, Ray......Quote
