Anidees AI5S Case Review
Anidees AI5S Review
Owing to it's small size, when we first clapped eyes on the box containing the AI5S from Anidees we were convinced the case inside could only be an M_ATX case at best.  Picking the box up did little to reassure us that we dealing with a decent product, so light was it that we felt it ought to be tied down if the wind picked up.  We further figured that as it was so light, it could hardly have a decent spec and was most liekly one of those bottom of the range cut price jobs we occasionally see.  We were though, very wrong on both accounts, as you'll shortly find out.
ColourBlack
Materials Steel and Plastic
Dimensions 430x220x470mm (HxWxD)
Weight5.96kg
Motherboard ATX, M-ATX
3.5" 5
2.5" 9 (3 shared with 3.5")
Front I/O 2xUSB3.0, 2xUSB2.0, Fan Controller, 2xAudio
Expansion Slots 8
Air Cooling
Front:   Up to 3x120mm/2x14mm (2x120mm included)
Roof:    Up to 2x120mm/140mm
Rear:    1x120mm/140mm (1x120mm included)
Water Cooling
Front:    240/280mm rad
Roof:     240/280mm rad
Rear:     120/140mm rad
Max PSU length 220mm, (350mm with HDD cage removed
Max GPU Length 340mm
Max CPU Cooler Height 175mm
«Prev 1 2 3 4 5 6 Next»
03-04-2017, 14:22:00
Avet
Why do I see Fractal Design Define C?Quote
03-04-2017, 14:45:40
AlienALX
Because you pretty much do
haha a mate of mine modded his Fractal by cutting it down quite severely. Then we get the Define C and now this funny how things go sometimes !Quote
04-04-2017, 01:34:49
Peace
The last picture on page 4 makes me cringe... A loosened screw/bolt?Quote
04-04-2017, 04:52:02
sheroo
Wish the Fractal C had come with a stock fan controller like this one does...Quote
04-04-2017, 10:38:26
Avet
I don't see the point with fan controlers now. Motherboards have plenty of connectors. You can go 3-way split on everyone of them.Quote
