Arctic Cooling Freezer 7 & 64 Pro Coolers
Introduction & Packaging
Search Reviews
The name Arctic Cooling is heavily embedded within the realm of PC enthusiasts, and really needs no introduction. This aftermarket cooling company continues to set the bar for many manufacturers with its intelligent and innovative approach to cooling. Not only are Arctic Cooling's products extremely effective at what they do, but, are on the whole visually aesthetic too. Today I have been fortunate enough to receive a box of sample goodies from Arctic Cooling, and it contains the latest additions to the Arctic Freezer series of aftermarket CPU cooling solutions for both Intel and AMD platforms.
Specifications
The technical specifications of the Arctic Freezer 7 Pro were taken directly from Arctic Cooling's website, you can find additional information here
*Heat Sink: 104 x 58 x 126.5 mm
*Fan: 107 x 43.5 x 96 mm
*Overall Dimensions: 107 x 96.5 x 126.5 mm
*Rated Fan Speed: 300 - 2500 RPM (PWM)
*Power Consumption: 0.16 Amp.
*Air Flow: 45 CFM / 77 m3/h
*Weight: 520 g
*Noise Level: 0.9 Sone
*Thermal Resistance: 0.17°C/Watt
*Thermal Interface Material: Pre-applied MX-1 Paste
*Warranty: 6 Years
(Accessed 15th October 2006)
Compatibility
Arctic Cooling specifies that the Arctic Freezer 7 Pro is compatible with the following CPU's:
* Intel Celeron (Socket 775)
* Intel Pentium 4 (Socket 775)
* Intel Pentium D
* Intel Core 2 Duo
Packaging and Contents
Arctic Cooling have taken the liberty of allowing the Arctic Freezer 7 Pro packaging speak for itself. It is simple and unassuming, it is very similar to the packaging of their 'L' series fans I reviewed a couple of months ago. One thing I would like to include about the packaging is that it is very sturdy and the fan inside is housed within an plastic shroud. You could be extremely confident of this fan arriving in one piece if it were being shipped to you.
Freezer 7 Pro front Freezer 7 Pro Spec
Arctic Freezer 7 Pro contents
Included inside the packaging were:
* 1 x Arctic Freezer 7 Pro cooler
* 1 x Installation booklet
* 1 x Arctic Cooling case sticker
Now that we've seen the specifications and contents of the Arctic Freezer 7 Pro, let's have a look at its AMD counterpart - the Arctic Freezer 64 Pro.
«Prev 1 2 3 4 5 6 Next»
02-11-2006, 09:36:04
PV5150
Looking at some aftermarket cooling for your Intel or AMD rig? Read on to see if the Arctic Cooling Freezer Pro series of coolers have what it takes.
Link to the review
