Arctic Freezer i30 Review
Up Close: Packaging and contents
Search Reviews
 Arctic Freezer i30
The i30 comes in a predominantly white box (Arctic White I guess).  As is usually the case the box gives details of specifications, compatibility and key features.
Arctic Freezer i30     Arctic Freezer i30
Inside we find the cooler is protected by two semi rigid formed clear plastic end caps.  they're not actually attached onto the cooler and come away really easily so no risk of ripped fingers and blood spurts.
The cooler comes with the fan already pre attached but it's easily removed by unclipping the square cowling section and then undoing the 4 allen bolts holding the fan into the cowling.  The fan has small rubber vibration dampening washers fixed to both sides of each screw hole to reduce vibration to the square cowling and to the body of the cooler.
Also included are some diagram rich instructions and all the fixing screws, thermal paste and brackets you'll need for your Intel installation.
«Prev 1 2 3 4 Next»
07-06-2012, 06:03:55
tinytomlogan
Well known for the Freezer 7 and 7pro, Arctic release the newest cooler in their range. Will it freeze or flop?
Continue Reading
07-06-2012, 06:10:54
FTR_4500MHz
" Continue reading " doesnt work tom .
EDIT : works now .
07-06-2012, 06:34:20
3930K
3980X? What on earth?
07-06-2012, 06:48:21
trazom
If 3930K do not know a colleague processor is certainly a mistake.
07-06-2012, 07:04:47
SieB
Not bad for the price.
07-06-2012, 07:14:06
3930K
Lol xD
