Bequiet Shadow Rock TopFlow Review
bequiet Shadow Rock TopFlow
be quiet have been around for a little while now, their core business being PSUs, fans, and as we see here CPU coolers.  Better known for the Behemoth units such as the Dark Rock Pro, be quiet have chosen to tread a slightly different path with their latest release.  The Shadow Rock TopFlow as the name suggests is a top down cooler, offering cooling not only to the CPU but also to the RAM, MOSFETs and VRMs.  Standing only 125mm high the size of the TopFlow lends itself perfectly to a wide selection of Mini, Micro and cube cases and of course HTPC cases.
Overall dimensions without mounting material (L x W x H), (mm)             171 x 137 x 126
Total weight (kg)        0.65
TDP (W)        160
LGA2011 ready        ✓
Socket compatibility        Intel: LGA 775 / 1155 / 1366 /1156 /
        AMD: AM2(+) , AM3(+) / 754 / 939 / 940 / FM1
Backplate Mounting        ✓
Fan model, number        Shadow Wings PWM 135mm
Anti vibration fan fixing        ✓
Overall noise level (dB(A)) @ 900/1250/100% (rpm)                              9.60 / 15.9 / 24.4
Heatsink specifications
Dimensions (L x W x D), (mm)        171 x 137 x 100
Number of fins        53
Fin material        Aluminium
Base material        Copper
CPU contact surface        CNC machined
Heatpipe number, Diameter (mm)                                                           4 / 8
Surface treatment        Nickel plated
General fan specifications
SilentWings-Fan dimensions (mm)                                                           135 x 135 x 25
Speed @ 100% PWM (rpm)        1500
Air flow @ 12V (cfm, m3/h)        66.8 / 113.6
Air pressure @ 12V (mm H2O)        2.10
Bearing type        Rifle
Rated voltage (V)        12
Input current (A)        0.22
Input power (W)        3
Connector        4-pin PWM
Cable length (mm)        200
Lifespan (h / 25°C)        200.000
Accessories
Thermal grease (g)        Dow Coming TC 5121 / 2
Backplate mounting set        ✓
User manual languages        DE, EN, FR, ES, PL
«Prev 1 2 3 4 5 6 Next»
26-03-2012, 05:42:44
tinytomlogan
We take a look at the latest cooler to be released from bequiet. Will the TopFlow flop or fly?
Continue ReadingQuote
03-04-2012, 12:37:03
NoobNeb
Low profile coolers seem to be all the rage atm Noctua, Phanteks and these guys. Good review.Quote
03-04-2012, 16:02:53
You_What?
How tall is it? Must have missed it quickly skimming the review, sorry.Quote
04-04-2012, 07:34:31
Jonnydude
lol, its on the very firs page
Overall dimensions without mounting material (L x W x H), (mm) 171 x 137 x 126'Quote
