BitFenix Prodigy M Review
Stripped
Stripped
Here we have it boys and girls, the verging on legendary BitFenix Prodigy chassis.  The front panel pops off easy enough, but to get the top and bottom off requires a screwdriver and bit of know how.  The majority of the external chassis is the same as the original Prodigy, and indeed the Phenom Mini-IX case we recently reviewed.  It's all steel and pretty darned well put together.
BitFenix Prodigy M Review     BitFenix Prodigy M Review
The front and rear of the chassis are much the same as other iterations of the Prodigy, even sharing the panel location holes with the Phenom
The only thing separating this from the Phenom M chassis is the row of holes along the roof that locate the roof panel on the latter.
«Prev 1 2 3 4 5 6 7 8 Next»
21-10-2013, 06:07:13
SieB
It's a shame that all they did was take the itx version and copy what the modders have been doing.
The case is a bit cramped for M-ATX, with the itx version you have plenty of room for decent water cooling and good airflow. You were also not restricted on the length of the GPU either.
I think Bitfenix could of put more effort in and made the case slightly bigger for the M-ATX version. Either that or just stick to the itx design but make the case wider so you can fit a M-ATX board in the way you fitted the itx one in the original Prodigy.
It's not a bad case and does the job, but I can't help thinking it could have been much better.Quote
21-10-2013, 06:11:05
Feronix
Exactly. There's too much compromise for my liking.
Surprised it got a Gold Award if I'm honest, but it was still a good read Quote
21-10-2013, 07:56:39
barnsley
This just makes me want to work on a M-ATX machine for myself even more now. The others are right though, there does seem to be too much of a compromise, I'd rather go for the Bitfenix phenom .Quote
21-10-2013, 08:01:57
tinytomlogan
Only the outside is different.Quote
21-10-2013, 08:16:27
Feronix
Just a question btw, I've noticed that the Phenom (mITX) has the exact same inside, including the 5.25" bay... Except the front panel is completely clean?
http://vorming.minatica.be/ict2013/B...henomMini1.jpg
Think I'm going for an mITX Phenom in white. Maybe slap a white Prodigy windowed panel on there, cause there's no windowed Phenom available...Quote
