Cooler Master Cosmos 2 Review
Cooler Master Cosmos S2 Review
Published: 3rd January 2012 | Source: Cooler Master | Price: £350 est |
It seems like an age since we first saw pictures leaked on the web about the Cosmos 2, it was just before the LITS show. I remember well because at LITS I was given a chance to get my hands on a Cosmos 2 at the beginning of December! The idea was a few select photos somewhere remote to try and give it a gangster kind of feel is a poorly lit dingy warehouse. Everything was arranged, location sorted, lights sorted, even costumes for people to give it that real 'Soprano's' feel. Then right at the last minute it was all pulled and Cooler Master whacked an NDA on everyone!
So the time has finally come that we can tell you all what we think of the Cosmos 2. Is it as good as the original Cosmos? Can Cooler Master keep the momentum created by the awesome CM Storm Trooper (our case of 2011)? Lets just move on and take a look at the specifications for the case, whilst reading those get comfy because we have a monster video review straight after!
Specifications
Stylish and streamlined race-car inspired design
Brushed aluminum and steel for strength and elegance
Airflow optimized design
Supports up to 10 fans and 13 HDDs (2 from X-dock)
Supports 4 Way SLI/CF
Supports XL-ATX / SSI CEB / SSI EEB boards
Advanced Control Panel:
4 channel fan speed control
I/O (USB 3.0 x 2, USB 2.0 x 4, e-SATA, Fan LED on/off switch)
Available Color | Midnight Black |
Materials | Exterior: Aluminum, Mesh, Synthetics;Interior: Steel-Alloy, Synthetics, Rubber |
Dimensions | 344(W) x 704(H) x 664(D)mm / 13.5 x 27.7 x 26.1 inch |
Weight | 22kg / 48.5 lb |
M/B Type | Micro-ATX, ATX, E-ATX, XL-ATX, SSI CEB, SSI EEB |
5.25" Drive Bay | 3 |
3.5" Drive Bay | 13 (2 from X-dock, Middle cage for 5 HDDs, Bottom cage for 6 HDDs) |
2.5" Drive Bay | 11 (converted from 3.5" bay) |
I/O Panel | USB 3.0 x 2, USB 2.0 x 4, e-SATA x 1, Audio In and Out |
Expansion Slots | 10+1 |
Cooling System | Front: 200mm LED fan x 1, 700 RPM, 19 dBA(converted from 120/140mm x 1) |
Top: 120mm black fan x 1, 1200 RPM, 17 dBA(converted from 200mm fan x 1/140mm fan x 2/ 120mm fa
Rear: 140mm fan x 1, 1200 RPM, 19 dBA | |
Side: 120mm fan x 2 (optional) | |
HDD: Mid.HDD: 120x25mm fan x 1 (optional)Bottom HDD: 120mm fan x 2, 1200 RPM, 17 dBA | |
Power Supply | ATX PS2 / EPS 12V |
Maximum Compatibility | CPU cooler height: 190mm / 7.48 inch |
Graphics card length: 385mm / 15.15 inch | |
Video Review
Lets hope the video covered all of your questions plus a few more you hadn't thought of as well, but we really should try and recap. The problem is the Cosmos 2 is just so feature packed we literally don't know where the best place is to start!
Ok lets start with the price. Rumors are that the Cosmos 2 will weigh in with a £350 price tag. Ouch right? Well let's face is £350 for a case is never going to be cheap is it. I have a funny feeling the only people that will moan will be people that want it and cant afford it. The case has though been designed and built for people looking to spend thousands on their system, people that wouldn't want to put a £3000 investment in a £100 case. Well for those lucky few Cooler Master have pretty much built a case to please you all. Not only that if you can't afford the Cosmos 2..... save for it. It really is worth every penny of that £350 asking price. The design is there, build quality, enough options to please pretty much everyone that's not wanting to go subzero.
Everything about this case screams quality, but not just that, it also shows what a manufacturer can do when they design a case for an enthusiast rather than for an accountant. We were all gobsmacked at the amount of options with this case. The ability to remove the lower HDD bays and fit a 240mm radiator was a high light for us, another was the fact this case is compatible with the EVGA SR2 and upcoming SR3.
So let's wrap this up. Multi-channel fan controller, dual radiator support out of the box, room for even the largest motherboards and graphics cards, ample cooling for even the hottest air rigs, plenty of cabling options, built like a tank and last but not least it looks the sex! We honestly think the aesthetics could only be bettered if it had a side panel window and if it was white! (Ok who wasn't expecting that one!!)
Cooler Master have kicked 2012 off with a bang, we honestly think they are back to their best and they've also delivered the case that all other big cases will be compared to. The other case manufacturers out there need to take their feet of the desks and get back to work. This is the case to beat, this is the best case on the planet. Will any one deliver a better option before the world ends in December? The race is on.
Thank you to Cooler Master for sending us one of the first few Cosmos 2's. You can discuss your thoughts in our forums.
£350 is a lot of money though, it has put me off it slightly tbh I was hoping for it being £250
Shame about not being able to fit a 60mm rad in the roof as well but with CPUs going 22nm, GPUs 28nm and SB not getting hot, temps are much lower anyway and using thinner rads isn't really a prob, as long as you aren't running 1366 or 2011 anyway. Also being able to fit two 240s in the bottom as well as a 360 in the top is more than enough for most situations.
But an epic case and an epic review non the less.
That thing is awesome! This will be perfect for SLI 780/XFire 7970 WC'd, now i just need to rob a bank.
Looking for it to get this one on my desk, but first coolermaster need to make side panel window option, and like lollipop said,I will have to rob a bank or someone rich
GOD THIS CASE IS GOOD!!! And TTL's review does everything perfect as usually! I was like - ooooh, daaamn, I'll have to buy this thing insted of CM Storm Trooper when I'll build my rig and it's going to add almost a 100 pounds to my build. I was literaly watching with such an excitement. And the BAAAAAAM!!!!!! "Yea I know this thing is going to cost three hundred and fifty quid...". 350 pounds?! Nooooooooooooo... Unfortunately almost 3 times more that a Storm Trooper kills it for me. I just won't be able to afford it. That made me sad...
And who told this case is cheap and rubbish? Zombie? It deffinately isn't cheap. Not by the price and by the looks of it. Everything seemed so high quality. The doors are aluminium, the hinges are coated in black chrome, the front panel slides like a spaceship's door, the buttons light up in 3 different colours, the fan door works amazing and clicks closed without you even pushing it to the end, I mean common, in what way is it cheap? Those couple of centimetres and a natively supported double rad setup at the bottom would have made this case PERFECT and unbeatable. I may have to admint, maybe I liked how the Storm Trooper looked a tiny bit better than this, atleast from the front, maybe not, haven't decided yet, but in real life this one would probably seem so much better and higher quality. Absolutely love it.
just
not hating just my opinion
i really dont understand why this got gold tbh £350? for a steel and plastic case... ok fair enough it has some decent watercooling options, it can fit anything, nothing that we havent seen before what with the rads in the floor and a 360 in the roof not hating just my opinion |
Cause everything is thought of and it's all so high quality. P.S. The sides are Aluminium. |
and it bloody well should be high quality it costs £350 and it prolly weights about 25KG for the price it should be fully aluminium
IS there going to be a window option on the side of the case. Because the side panels look plastic. (ah you answered in the vid. you'll have to contact them and ask)
I'm not as sold on this case as I first was and I have been waiting a long time for it but the little things like not supporting a full 60mm thick rad and a few other little things have made me think twice. In my opinion £350 is more than it's worth, £250 fair enough but not £350.
And thats not because I can't afford it, theres a difference between having money to spend and having the sense on what to spend it on.
I think i'm going to wait a while before deciding whether to get one or not, don't get me wrong though I still think it's an epic case and I do still want one.
It has disappointed me as well, even more so because I bought a RX360 (60mm thick) months ago for when I get one I'm not as sold on this case as I first was and I have been waiting a long time for it but the little things like not supporting a full 60mm thick rad and a few other little things have made me think twice. In my opinion £350 is more than it's worth, £250 fair enough but not £350. And thats not because I can't afford it, theres a difference between having money to spend and having the sense on what to spend it on. I think i'm going to wait a while before deciding whether to get one or not, don't get me wrong though I still think it's an epic case and I do still want one. |
great case
(money is no object - girls are only objects)
I'm actually amazed as the comments - I thought there would be a few more fans - I suppose at the end of the day its price will dictate its popularity.
I'm still waiting for someone to produce a case that as standard fits a fat 360 in the roof and a fat 240 vertically in the front instead of all that hard drive space that I don't need. I'm sure it could easily be done... I'm actually amazed as the comments - I thought there would be a few more fans - I suppose at the end of the day its price will dictate its popularity. |
im jusr curious of how much rooms in the bottom height wise with all brackets removed.. as id like to put a phase change unit in the bottom of one these
Here is a link to a really nice Cosmos II mod with the radiators in the top: |
Amazing review as always but are you sure it supports a SR2 Motherboard? According to Coolermaster it supports a SSI EEB max which is 305 × 330 mm (12″ × 13″) & SR2 is a HPTX which is 345.4 x 381mm (13.6" x 15"). Also I own a Xigmatek Elysium currently, is this case worth upgrading from it? |
hopefully come down in price once they are more available
overclockers.co.uk have it up for preorder now for 339.98 says due in on the 14/02 hopefully come down in price once they are more available |
So SieB, have you made up your mind yet? Do you think you'll be getting one? |
I'm thinking of doing what Coolmeister did and cut the extra section in the roof for another fan and fit a 480 in the roof. That part is easy enough, the only thing i'm worried about if I do it is cutting the vents in the bit that slides over the fan control to vent the air from the extra fan cutout for the 480 rad. Might have to try and get a spare one of those from CM if I can incase I mess it up, I have never modded a case in my life and i'm not to good at stuff like that.*
I still want to get one but i'm gonna wait to see what happens with the windowed version first and i'll let the dust settle a bit to see if prices drop a bit more as well. I'm thinking of doing what Coolmeister did and cut the extra section in the roof for another fan and fit a 480 in the roof. That part is easy enough, the only thing i'm worried about if I do it is cutting the vents in the bit that slides over the fan control to vent the air from the extra fan cutout for the 480 rad. Might have to try and get a spare one of those from CM if I can incase I mess it up, I have never modded a case in my life and i'm not to good at stuff like that.* |
Rather you than me take a dremel to a £300 case. Wouldn't you be able to get away with a 360 & 240? The XSPC EX 360 looks to be perfect for the top. |
I could use a 360 and a 240 but i'm thinking of just using a 480 in the roof and going for a silent rig more than getting it as cool as possible. One 480 should be enough for my needs though, i'll only be cooling my 2500k to start with, Ivy bridge later which will be cooler still and then when I upgrade my GPU it will be a 28nm one so temps wont be that high either and I could always add a 240 later on if I add another card.
I ordered five from the US for £3.75 inc P&P
looking at the kit TTL reviewed to make it simple for myself
Let me know if you go for it SieB as i've got another four 22cm extension cables for the fan controller /power PCB. I ordered five from the US for £3.75 inc P&P |
anyone knows what's finally mountable?
They won't ship this case to the UK. and the places over in the states that have it in stock are doing $120 shipping.
So I'm asking is there a good place over here (UK) to get this case? at a reasonable price. And since I'm US military I think I'm VAT excluded
£286 with free shipping
http://www.amazon.co.uk/Cooler-Master-Cosmos-USB-Case/dp/B006G19KTE/ref=sr_1_1?ie=UTF8&qid=1353951068&sr=8-1
grrr, ill just have my corsair 800d shipped from home
ya thats around $460 american. ouch. $160 more then the states amazon.com
grrr, ill just have my corsair 800d shipped from home |
http://www.ebay.co.uk/itm/380446204719?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1423.l2649
but because its not in the UK im not sure if you have to pay like import taxes from another EU country best to contact them to see if they know or maybe someone on Oc3d
After what seems like an eternity of waiting since the first images of the Cosmos 2 were first leaked OC3D can proudly bring you its review of the Cosmos 2.
Continue Reading
