Cooler Master Eisberg 120L Prestige Review
If you want to get into water cooling but are a bit put of, or quite frankly terrified of the thought of putting together a custom water loop then you will quite naturally be drawn to one of the many AIO solutions on the market today.  But what of the future?  There may come a time when your knowledge, experience and confidence combine to out weigh the burdon of terror and the urge to build a custom loop becomes irresistible.  What will happen to that expensive AIO solution then?  If only you could re use it, or maybe even just part of it to lessen the pain of the financial sting from binning it or selling it on.
On the face of it the Eisberg from Cooler Master appears to be just another AIO water cooler.  Look a little deeper and you'll notice several features that indicate that the Eisberg is something a little different.  With both the Radiator and Pump/res assemblies having compression fittings, and the pump/res having a fill port it becomes possible to change any of the core components, meaning the future expandability alluded to above becomes a very real option.  With this in mind lets look at the technical specification to see just what £119 gets you.
Intel Compatibility
  Socket   2011
  Socket 1366
  Socket 1156
  Socket 1155
AMD Compatibility
  Socket   FM2
  Socket FM1
  Socket AM3+
  Socket AM3
  Socket AM2+
  Socket AM2
CPU Waterblock
Copper Jet stream Enhanced Bi-Directional Micro Channel CPU Water block
Pump
German Designed, Axial rotation, Ceramic Bearing
Pump Head Pressure
2.2 Metres
Pump Volume
 400 Litres/Hour
Pump Noise
25dBA
Pump Speed
3600RPM (1950 with 9v adaptor)
Tubing
10/8mm  Black with Black anti kink coil
Radiator
1 x 120mm 100% Copper
Radiator Dimensions
156 x 124 x 30mm (without fan)
Fan
2 x 1600 rpm Cooler Master Fans
Fan Connection
3 Pin
Fan Airflow
60.2 CFM
Fan Noise
20.5 dBA
Special Features
All In One CPU Cooler
Can be Expanded
Micro Channel Technology
Package Contents
1x Cooler Master Eisberg
2 x 120mm Fans
Mounting Hardware
Factory Filled Coolant
Features
  • German designed pump provides stable and strong water pressure
  • JetStream Technology – provides turbo injection of water inside the water block
  • Improved cold plate design:
  • Large Micro Channel contact area
  • - 100% copper
  • - Fine cut Jet Plate
  • - Integrated pump and  water block
«Prev 1 2 3 4 5 6 7 Next»
10-06-2013, 08:59:48
Greenback
interesting results, shame you didn't get the 240 version seems to do well in reviews.
Haven't cooler master been saying they are going to fix the noise since last year as it seems by other reviews as well it has noise issues.
But at £130 for the 240 version that's getting into Xspc kit range or even Swiftech H220 + another 240 rad, which makes it well over priced imoQuote
10-06-2013, 17:46:54
airdeano
aye, shoot the flare, the eisburg has capsized and is sinking quickly. the sounds
of the swelling whitecaps are drown out by the 7v pump growl! was really looking
forward to seeing this and its 240 brother really take off, instead of taking its last
gulp of coolant before up-ending.. too badQuote
10-06-2013, 23:27:09
Mgutierrez33
*Jayne Cobb voice* ... Well that's just damn disappointing'.
Oh well, I suppose you can't win them all. Plus, based on the specs of that pump it really wouldn't do ti add much more into the loop apart from a 240 mm rad and possibly including a MOSFETT block, but I wouldn't throw much more at it than that really.Quote
17-06-2013, 05:18:02
You_What?
Wil give this a read later tonight, been looking at at a 120mm AIO but the 240mm version caught my eye with the expandability?Quote
17-06-2013, 06:30:20
Greenback
If you want a 240 with expandability then look at the swiftech H220Quote
