Cooler Master Eisberg 120L Prestige Review
Op Close: The Cooler Overview
Up Close:  The Cooler Overview
The first thing you notice about the Eisberg 120 is the size and sheer bulk of the cold plate assembly.  The expanded diagrams towards the bottom of this page best describe why this is so, but suffice to say that the cold plate also doubles as a small (Very small) reservoir.
Cooler Master Eisberg 120L Prestige Review     Cooler Master Eisberg 120L Prestige Review
The Eisberg has very flexible high gloss black tubing, which when coupled with the gloss black anti kink coils should make for easy installation into cramped spaces.  With 35cm total distance from black to radiator the Eisberg has just that little bit more tubing length that than most AIOs.  And if it's still not long enough, or perhaps even too long it can always be cut down or swapped for longer.
The images below are taken from the Cooler Master website and illustrate well the technology utilised in the construction of the Eisberg.
Bi Directional Micro channels and Jet stream technology up close.
«Prev 1 2 3 4 5 6 7 Next»
10-06-2013, 04:19:34
tinytomlogan
With only only 10% of an Iceberg visible above water there's a lot that's not immediately obvious. But does the Eisberg from Cooler Master have hidden depths?
http://www.overclock3d.net/gfx/artic...081521495l.JPG
Continue ReadingQuote
10-06-2013, 08:59:48
Greenback
interesting results, shame you didn't get the 240 version seems to do well in reviews.
Haven't cooler master been saying they are going to fix the noise since last year as it seems by other reviews as well it has noise issues.
But at £130 for the 240 version that's getting into Xspc kit range or even Swiftech H220 + another 240 rad, which makes it well over priced imoQuote
10-06-2013, 17:46:54
airdeano
aye, shoot the flare, the eisburg has capsized and is sinking quickly. the sounds
of the swelling whitecaps are drown out by the 7v pump growl! was really looking
forward to seeing this and its 240 brother really take off, instead of taking its last
gulp of coolant before up-ending.. too badQuote
10-06-2013, 23:27:09
Mgutierrez33
*Jayne Cobb voice* ... Well that's just damn disappointing'.
Oh well, I suppose you can't win them all. Plus, based on the specs of that pump it really wouldn't do ti add much more into the loop apart from a 240 mm rad and possibly including a MOSFETT block, but I wouldn't throw much more at it than that really.Quote
17-06-2013, 05:18:02
You_What?
Wil give this a read later tonight, been looking at at a 120mm AIO but the 240mm version caught my eye with the expandability?Quote
17-06-2013, 06:30:20
Greenback
If you want a 240 with expandability then look at the swiftech H220Quote
19-06-2013, 05:23:05
G-Dubs
We've actually got the 240 version in the labs here at OC3D towers and will be reviewing it soon.Quote
19-06-2013, 05:50:28
tinytomlogan
Actually Dubs has it at his house Quote
19-06-2013, 06:01:53
Greenback
It would be nice to see how it performs, however the price of the 240 version is way to much considering other AIO's and available kitsQuote
19-06-2013, 10:10:34
Mgutierrez33
SSSSSSHHHHHHH, no one must know his secret O_O
Srsly hoping this one has any shred of anything better (comparatively) going for it than the 120 model did. I actually did notice that in general the pumps for the Cooler Master AIO's are all pretty noisy, but when my gf's PC is running you can't make it out unless your head is right near the top exhaust of the 690II. Still, quiet, quality performance is what we aim for.Quote
26-06-2013, 06:10:20
You_What?
Tell him to stop hogging it and that your viewers are waiting!!!
Why TTL would you let him do that? Why? Quote
14-07-2013, 10:54:43
Vlada011
I like this diagram it's best on NET.
H100i is for me best option today and X60 Extreme.
It's really weird how X60 is better than H100i but that's it.
I like because and CM start to make this all in one.
Any of them is better than massive coolers.
And price difference is not so big any more.Quote
