Cooler Master Eisberg 120L Prestige Review
Whether or not you consider the Eisberg as a serious proposition depends very much on what you intend to do in the future.  Looking at the performance charts and bearing in mind the £120 price tag it'd be reasonable to suggest that you might be much better of with one of the cheaper and better performing AIO systems such as the X40 H100 or H100i, or for that matter the even cheaper Seidon or H60.  And if you can guarantee you're never going to want to advance to a custom loop then these are most likely the better options for you.
If however you suspect that having gotten your feet wet you may feel tempted to go the whole hog and build a custom loop then the Eisberg offers something that the others do not.  Modular design, Expandability, call it what you like but the Eisberg isn’t simply an AIO.  It offers something the others don’t.  Albeit at a price (and a big price at that).  Should you wish, each of the main components of the Eisberg can be re-used in whole or as part of a fully custom loop.  With this in mind, it is then only fair that we look at what else your £120 will get you.  Taking a gander around a few of our favourite e-tailers we can indeed piece together a similar spec'd (if not slightly better) setup for  pretty much the same price.  Would you be better off doing this rather than buying the Eisberg?  Well it depends on your ambitions.  If you want to put together your own loop then selecting your own components separately is the better way to go.  If you're not quite ready to put your own loop together then maybe, just maybe the Eisberg has something to offer.
We say maybe because there are a few other things to think about while mulling over that potential purchase.  From a practical view point the Eisberg is fairly easy to install but does present several opportunities to grind your teeth and practice your "naughty" words.  For starters it could benefit from better instructions as the diagrams on those provided are comedy small.  The radiator/fan/floppy rubber baffle assembly is a bit of a fiddle, actually, it's a lot of a fiddle with the rubber baffle forever falling into the fan blades while you try to line all the holes up.  On the plus side, and yes there are some positives, the cold plate assembly although bulky is simple to locate in place and the chosen method of attachment to the Motherboard is simplicity itself, with no risk of over-tightening the screws.
In use the fans were reasonably quiet on the low setting (via the 3 speed molex/fan adapter) but became more noticeable on the medium and high 12v setting that we test at.  Still these are 1600RPM fans so they're always going to emit a bit of a whir at full tat.  The pump however emitted more than “A bit of a whir” and was much louder than expected as well as being louder than any other pump we've ever heard, drowning out the noise of the fans at both the 12v and lower voltage settings.  Regrettably we found noise emitted to be intrusively audible through the case sides with the observer sitting 2-3 feet away as it would be in the average desk top set up.  When the Eisberg was released, which is now some time ago, there were quite a few comments floating around that the pump was very noisy.  Cooler Master were assuring that this was a characteristic of the pre release versions and would be fixed so as not be of detriment in the final retail version.  Unfortunately we have to say that many months down the line the issue does not appear to have been rectified and that the noise produced by the pump whether it be at the full 12v, reduced via the included cable, or even attached directly to a motherboard header is still intrusively and unacceptably loud. We actually contacted Cooler Master about the problems we were having and they thought it might be faulty so sent us a second one. Sadly the replacement unit was exactly the same no matter what we tried to do to tame the noise, the only thing that seemed to change was the pitch of the pump rather than the volume of the noise created. If you take into account the eye watering £120 price tag, lack luster performance and quite plainly annoying pump noise we feel we have to say that this is a rare misfire for Cooler Master and we would not recommend you buy this product at all.
Thanks to Cooler Master for the 120L on review today, you can discuss your thoughts in the OC3D Forums.
«Prev 1 2 3 4 5 6 7 Next»
10-06-2013, 04:19:34
tinytomlogan
With only only 10% of an Iceberg visible above water there's a lot that's not immediately obvious. But does the Eisberg from Cooler Master have hidden depths?
http://www.overclock3d.net/gfx/artic...081521495l.JPG
Continue ReadingQuote
10-06-2013, 08:59:48
Greenback
interesting results, shame you didn't get the 240 version seems to do well in reviews.
Haven't cooler master been saying they are going to fix the noise since last year as it seems by other reviews as well it has noise issues.
But at £130 for the 240 version that's getting into Xspc kit range or even Swiftech H220 + another 240 rad, which makes it well over priced imoQuote
10-06-2013, 17:46:54
airdeano
aye, shoot the flare, the eisburg has capsized and is sinking quickly. the sounds
of the swelling whitecaps are drown out by the 7v pump growl! was really looking
forward to seeing this and its 240 brother really take off, instead of taking its last
gulp of coolant before up-ending.. too badQuote
10-06-2013, 23:27:09
Mgutierrez33
*Jayne Cobb voice* ... Well that's just damn disappointing'.
Oh well, I suppose you can't win them all. Plus, based on the specs of that pump it really wouldn't do ti add much more into the loop apart from a 240 mm rad and possibly including a MOSFETT block, but I wouldn't throw much more at it than that really.Quote
17-06-2013, 05:18:02
You_What?
Wil give this a read later tonight, been looking at at a 120mm AIO but the 240mm version caught my eye with the expandability?Quote
17-06-2013, 06:30:20
Greenback
If you want a 240 with expandability then look at the swiftech H220Quote
19-06-2013, 05:23:05
G-Dubs
We've actually got the 240 version in the labs here at OC3D towers and will be reviewing it soon.Quote
19-06-2013, 05:50:28
tinytomlogan
Actually Dubs has it at his house Quote
19-06-2013, 06:01:53
Greenback
It would be nice to see how it performs, however the price of the 240 version is way to much considering other AIO's and available kitsQuote
19-06-2013, 10:10:34
Mgutierrez33
SSSSSSHHHHHHH, no one must know his secret O_O
Srsly hoping this one has any shred of anything better (comparatively) going for it than the 120 model did. I actually did notice that in general the pumps for the Cooler Master AIO's are all pretty noisy, but when my gf's PC is running you can't make it out unless your head is right near the top exhaust of the 690II. Still, quiet, quality performance is what we aim for.Quote
26-06-2013, 06:10:20
You_What?
Tell him to stop hogging it and that your viewers are waiting!!!
Why TTL would you let him do that? Why? Quote
14-07-2013, 10:54:43
Vlada011
I like this diagram it's best on NET.
H100i is for me best option today and X60 Extreme.
It's really weird how X60 is better than H100i but that's it.
I like because and CM start to make this all in one.
Any of them is better than massive coolers.
And price difference is not so big any more.Quote
