Cooler Master Eisberg 240L Prestige Review
Up Close:  Pump/Contact plate
The 240L Prestige shares exactly the same pump/contact plate as the 120L model and is also available for purchase as a stand alone item.  Roughly cuboid in shape the pump is considerably more chunky than those found on stand alone AIO systems, the reason for this being a more powerful pump and that the pump/contact plate assembly also doubles up as a small reservoir, having as it does a fill port on the top.
Cooler Master Eisberg 240L Prestige Review     Cooler Master Eisberg 240L Prestige Review
The Inner workings can be seen through a small window in the side of the unit with the clear fluid inside affording an unobstructed view of the impeller.
The Copper contact plate is a highly polished affair and although not devoid from imperfections and blemishes they are not so serious thet they will affect performance.
Cooler Master Eisberg 240L Prestige Review     Cooler Master Eisberg 240L Prestige Review Â
