Cooler Master HAF XB Case / Test-bench Review
Published: 28th January 2013 | Source: Cooler Master | Price: £82.99 |
History it seems, is a bit vain. History it seems has a habit of inserting page markers into its own timeline, deciding as it were to draw your attention to the start or end of certain chapters. Inserting markers that cause people to instinctively remember where they were and what they were doing when certain momentous events occurred. The Death of Elvis, The First Moon landing, The Twin Towers, the first time you saw a actual naked woman. If you're a geek then history may well have chosen other events to mark your journey through life (apart from the naked woman one, that's pretty much universal). If this is the case, then along with the birth of online gaming and a version of windows that didn't suck more than the last one, most likely the inception of the Cooler Master HAF series is one such event. Am I over egging this? perhaps a little, but the fact remains that the HAF marked a significant point in PC case history.
So successful is the HAF that Cooler Master feel confident that they can stir the pot a bit, changing the footprint and form factor of the case whilst at the same time remaining true to the original design concepts and styling cues. Gentleman and ladies (for we know there a some of you out there). We bring you the HAF XB. A Mid tower (sort of) ATX case eschewing the conventional in favour of a double decker layout. PSU and drives below, Motherboard and cooling up top. Able to accept tall coolers and long cards, the XB offers even more. Twiddle a few thumb screws stripping away the body, and the XB transforms itself into a Test bench. Looks like we need to put it through the OC3D wringer and see if this latest incarnation is able to uphold the name of HAF.
| Material | Steel body, front mesh, Plastic Bezel |
| Dimensions | 442/330/423mm W/H/D |
| Weight | 8.2kg |
| Motherboard support | ATX, Micro ATX, Mini ATX |
| 5.25" | 2 |
| 3.5" | 2 (from X-Dock) |
| 2.5" | 6 (2 from X-Dock) |
| I/O Panel | 2xUSB 3.0 Audio in/out, supports HD audio |
| Expansion Slots | 7 |
| Cooling | Front 2x120mm 1800rpm 21 dBA Included (2x 140mm optional) Rear 120mm optional 2x80mm optional Top 200mm optional |
| Water cooling support | Front optional 240 or 280mm Radiator Rear optional 120mm radiator |
| Powers Supply Support | ATX PS2 max mength 180mm |
| Max GPU | 334mm |
| Max CPU | 180mm |
I have 5x 3.5" drives and 2x 2.5" SSD's (patriot pyro 128's in RAID 0) I need to fit.
I'm pretty sure with all the room in the bottom hard drive area (2.5" cage area) I can make something work to where I can either add a 3.5" cage or just drill out the 2.5" and just replace that cage. I've got plenty of sheet metal and car guys that have the tools who work with me in the Air Force.
But then I look at the cosmos 2 and really drool over all the area it has. But then I'm reminded that in 3 years the military movers are going to be handling my stuff again and quite possible are going to break another $300 case.
Both cosmos 2 and haf xb fit the new 280mm all in one water coolers, thats a must have for me with a new case.
AHHHHHH I'm torn. I'm leaning towards the HAF XB
Btw I just purchased this case with my new build about a month ago and say I love it. With some quieter fans I could make it much better on the ears. But really, if you buy a HAF case, you aren't bothered by some wind noise.
EDIT: Also if you have the Noctua NH-D14 it fits like a charm. You won't be able to put the 240mm fan on top but the cooling is good enough you don't need to.
One of my MSI 560ti Twinfrozr fans went out on me and it still stays plenty cool enough in this case. Very very pleased.
http://www.overclock3d.net/gfx/artic...160321682l.jpg
Continue Reading
