Cooler Master Hyper Z600 CPU Cooler
The front of the box of the Z600 is fairly plain, but rather eye catching. There is a glossy cut out of the cooler attached in the centre, so that it is raised from the rest of the box, with a black outer glow surrounding the edges. It also features the Cooler Master Logo and product name.
The remainder of the box contains product details, specifications and shows a few images of the cooler in action.
Once inside the outer shell, you are presented with the internal packaging. This consists of two main pieces that split apart leaving the cooler in the middle. There is foam padding inside each compartment, protecting the cooler from damage during transit.
All of the accessories are concealed neatly in the end of the large compartment and pulling up the edge reveals two plastic re-sealable bags containing all the accessories. Inside there is a warranty slip, fan mounts, mounts for sockets AM2 & 775 and a nut/screw thread used for attaching the cooler to the motherboard with the supplied screws.
When you first set your eyes upon the cooler you are immediately amazed by the size of the thing. To put it simply, it is HUGE. Upon removing it from the packaging you also notice another thing – weight. The thing weighs a ton, and is incredibly solidly built. The fins are solid, and do not bend easily, and the base is nicely finished and smooth.
Comparing the Z600 to the stock Intel cooler, you get a very good idea for size; the stock cooler is just above the height where the fins on the Z600 start. Talking of heatpipes, you may also notice that the Z600 has a fair few of them – 6 in total.
