Cooler Master Hyper Z600 CPU Cooler
Test Results
We have added in results for the Intel Stock Cooler and an Arctic Cooling Freezer 7 Pro. This will give you an idea of how it performs, compared to other cooling products. The ambient temperature throughout testing was constantly around 26°, only differing by a degree at the most.
For the Stock testing we tested the Z600 with no fans attatched, this gives you a good idea of how it will perform ‘out of the box’ with just the case fans for airflow.
As you can see, the Z600 sits pretty much in the middle of the group here, however, since it is completely silent the results are rather good.
Here the Z600 pulls out quite a lead. The temperatures raise only a small amount compared to idle, where as the Freezer 7 and Stock cooler go up by quite a margin. A very impressive result for the Z600.
With the CPU now at 3Ghz it was kicking out quite a lot of heat. However, the Z600 (now with fans attached) handled it without breaking into a sweat and easily beat the Freezer 7 by quite a margin; another good result.
Once again the Z600 proved to be extremely capable. It easily beat the Freezer 7 and kept the Q6600 at very reasonable temperatures. The Z600 cooler has proven that it is a very capable partner to a hot running quad-core.
