Cooler Master Nepton 140XL Review
Cooler Master Hepton 140XL Review
The Nepton range from Cooler Master joins the Seidon and Eisberg, adding 140mm radiator performance to the series. The Nepton is available in two flavours, the 280L which is a 280mm rad based set up having fans on one side and the 140XL we have for review today.  Being based on a 140mm as opposed to a 120mm radiator the Nepton should, we hope, give reasonable results in our torture tests.  However being bigger than 120mm rad based systems it may not fit into quite as many cases as its smaller brethren.  That said with a good few SFF cases also offering 140mm fan support, in particular the Prodigy chassis based cases from Bitfenix, so aside being compatible with a great many of the Cooler Master range of cases, we don't think size will be too much of a limiting factor, that is of course provided the arduous torture tests don't throw us any surprises.
 Model Nepton 140XL
 CPU Socket
 Intel:  2011, 1366, 1150, 1155, 1156, 775
 AMD:  FM2. FM1, AM3+, AM3, AM2
 Dimensions 47x69.8x49.1mm
 Radiator Dimension 171x139x38mm
 Fan Dimensions 140x140mm (supports 120mm fans also)
 Radiator Material Aluminium
 Fan Speed 800-2000 RPM +/- 10%
 Fan Pressure 0.7-3.5mm H20
 Fan Airflow 54-122.5 CFM
 Fan Noise 21-39 dB(A)
 Pump Noise <25 dB(A)
 Pump Power 2.9W
«Prev 1 2 3 4 5 6 Next»
05-03-2014, 04:12:50
Let's take a look at the Nepton 140XL, the latest twin fan, 140mm rad based AIO from Cooler Master
Continue ReadingQuote
05-03-2014, 06:38:38
Well done coolermaster. Its nice to have a AIO that looks good from them. Especially one with a quieter pump then the seidon.Quote
12-03-2014, 19:06:06
The Seidon isn't too bad, but the Eisberg range are atrocious.Quote
