Cooler Master Seidon 120M Review
Up Close: Cooler Overview
Although an all new design the Seidon treads a familiar path.  A slim rad measuring just 27mm in depth is coupled with a pump/cold plate assembly by means of 300mm corrugated tubing.
Cooler Master Seidon 120M Review     Cooler Master Seidon 120M Review
If you're thinking the plastic corrugated tubing lacks the flexibility of some of the rubberised tubing seen on other coolers you'd be wrong.  It's ever bit as flexible and short of hitting it with a hammer guaranteed not to kink
The Seidon comes with a Cooler Master fan (resplendent with a Cooler Master logo on one of it's blades).  The fan is a 600-2400 RPM model with manufacturers specifications rating it at between 19 and 40dBA.  Looks like at full tat we can expect this fan to produce a little less than a gentle susurration.
«Prev 1 2 3 4 5 6 7 Next»
03-04-2013, 09:51:58
Master&Puppet
Looks like a reasonable alternative to some of the mid-range tower coolers on cooler systems although it seems pretty noisy.Quote
03-04-2013, 09:53:19
barnsley
I was hoping you'd review this! I've been looking at AIO coolers for my new build for sometime and I wondered about this. Definitely going on my parts to buy list Quote
03-04-2013, 10:06:56
UkGouki
its a pretty good choice if you only wont a moderate overclock tbh im thinking of getting this as funds at the mo are tight and it will get me what i want out of my system Quote
03-04-2013, 12:29:02
lwatcdr
I just do not get it. Why does everyone just use fan controllers and such when modern Motherboards have fan headers and heat sensors. Why can't people set a max CPU temp of say 60c and let the computer spin the fan up and down as the load changes? You could then alway have the lowest noise for a given temp. Seems like this should be an automated function.Quote
03-04-2013, 14:20:06
alpenwasser
I can only speak for myself but I have yet to possess a motherboard that
  • has enough fan headers for my needs in the right locations and/or
  • provides enough power on its fan headers to power an array of fans,
  • provides enough power for a D5 pump (I know they can be hooked up to the PSU directly and the Vario can be adjusted without a fan controller, but it's much more comfortable not having to use the little nob on the pump's back, and yes, I do change my pump's speed from time to time, albeit not often) and
  • lets me define not only max temps but actual fan curves, because everything else is useless (to me, at least).
These are unlikely to change in the future. It's not really reasonable to build a M/B with 10 to 12 fan headers (which you can easily use with two radiators on push/pull or something comparable) or fan headers that can provide ~30 W of power for a pump (market is too small).
The fan curve thing should be feasible though, I'll admit. I don't want my fans spinning up to 100% when a certain max temp is hit, I want them to ramp up by maybe 20% to see if that's enough and then throttle down again.
If you look at a real fan controller like the Aquaero, that's a very complex tool. You don't just integrate something like that into a M/B. It is certainly feasible, but it would cost accordingly.
Overall I'd say cost is probably the reason why the M/B that fits my needs regarding fan control is unlikely to arrive any time soon, and as long as that I'll stick to fan controllers. Besides, I like fan controllers, they have knobs and buttons and displays and stuff Quote
