Cooler Master Seidon 120M Review
Testing
Testing
Intel i7 3960X Stock@ 1.1v (undervolted) 4.0GHz @ 1.25v 4.4GHz @ 1.35v 4.6GHz @ 1.45v Gigabyte X79 UD3 Corsair Vengeance LP Memory Corsair HX850 V2 Corsair Force GT 60GB Coolermaster Storm Trooper
As usual we'll be testing our coolers at varying  levels of overclock and increasing levels of voltage.  this in turn of course means increasing levels of heat which the coolers need to dissipate.  To begin with we start with the undervolted stock speed.  Why undervolted? well if you have things set on "Auto", you may well be using more volts than are actually required to run at the chosen frequency, for example our 3960s will run quite happily at just 1.1volts, solid as a rock, 24/7, and as such we use this as our starting point.
Continuity is very important in testing, and for this reason we keep as many of the potential variables as locked down as possible.  We will be using OCCT in Linpack X64, AVX compatible with all logical cores tested and 90% free memory utilised. The test is set up to run automatically with just a few clicks to set it going.  A 10 minute idle followed by 30 minutes of testing and a 5 minute cool down is the order of the day and brings the total test time per clock speed to 45 minutes.  So as to remove subjectivity in determining whether a CPU has failed, OCCT is set to stop the test and register a fail should the max temp exceed 80 degrees.  In testing we noted that if even just one of the cores exceeds 82 degrees OCCT halts the test and a fail is recorded.
Turning now to the 4GHz test we up the voltage to 1.25 volts, this is what is deemed normally as stock volts. Something we are always harping on about on the forums is AUTO does not mean stock volts, and normally if you overclocking with "auto" volts the motherboard will be upping the volts much more than needed if you were to do it manually. By whichever means it happens, upping the volts (especially from our 1.1v undervolt) does have a big impact on temps, with an average increase of 10-15 degrees seen in the results.
Upping the volts still further we achieve a stable 4.4GHz overclock at 1.35 Volts. It's here we start to separate the wheat from the chaff, with lesser coolers not able to disperse the increased heat effectively. Again we see a jump of 10 degrees or so from the figures at 4GHz. Both the H100 and the well respected D14 are creeping into the 70s here, indicating that only the cream of the crop will excel at this level.
With the temps being only slightly better than those of the Corsair H60 we weren't really expecting the 120M to make it through the hardcore 4.6GHz test, and guess what, it didn't!
«Prev 1 2 3 4 5 6 7 Next»
03-04-2013, 09:51:58
Master&Puppet
Looks like a reasonable alternative to some of the mid-range tower coolers on cooler systems although it seems pretty noisy.Quote
03-04-2013, 09:53:19
barnsley
I was hoping you'd review this! I've been looking at AIO coolers for my new build for sometime and I wondered about this. Definitely going on my parts to buy list Quote
03-04-2013, 10:06:56
UkGouki
its a pretty good choice if you only wont a moderate overclock tbh im thinking of getting this as funds at the mo are tight and it will get me what i want out of my system Quote
03-04-2013, 12:29:02
lwatcdr
I just do not get it. Why does everyone just use fan controllers and such when modern Motherboards have fan headers and heat sensors. Why can't people set a max CPU temp of say 60c and let the computer spin the fan up and down as the load changes? You could then alway have the lowest noise for a given temp. Seems like this should be an automated function.Quote
03-04-2013, 14:20:06
alpenwasser
I can only speak for myself but I have yet to possess a motherboard that
  • has enough fan headers for my needs in the right locations and/or
  • provides enough power on its fan headers to power an array of fans,
  • provides enough power for a D5 pump (I know they can be hooked up to the PSU directly and the Vario can be adjusted without a fan controller, but it's much more comfortable not having to use the little nob on the pump's back, and yes, I do change my pump's speed from time to time, albeit not often) and
  • lets me define not only max temps but actual fan curves, because everything else is useless (to me, at least).
These are unlikely to change in the future. It's not really reasonable to build a M/B with 10 to 12 fan headers (which you can easily use with two radiators on push/pull or something comparable) or fan headers that can provide ~30 W of power for a pump (market is too small).
The fan curve thing should be feasible though, I'll admit. I don't want my fans spinning up to 100% when a certain max temp is hit, I want them to ramp up by maybe 20% to see if that's enough and then throttle down again.
If you look at a real fan controller like the Aquaero, that's a very complex tool. You don't just integrate something like that into a M/B. It is certainly feasible, but it would cost accordingly.
Overall I'd say cost is probably the reason why the M/B that fits my needs regarding fan control is unlikely to arrive any time soon, and as long as that I'll stick to fan controllers. Besides, I like fan controllers, they have knobs and buttons and displays and stuff Quote
