Cooler Master Silencio 452 Review
Up Close:Â Exterior Rear and Base
Well we had to have a section called Rear and base, even if it is only just a small one. “Oooop top” as they say “Oooop North” there’s the usual rear I/O cut out alongside a fan grill fitted with a 120mm fan but also able to accept 90mm and 80mm sizes should you for some bizarre reason decide that you need less ventilation and more noise.
Â
The case stands of four fairly basic plastic feet which are clipped in as opposed to screwed in. The multitude of screw holes down here should hint that the interior base is a fairly fun packed area. At the rear of the base there is a small grilled area with a rather flimsy but none the less effective extractable mesh filter.
