CoolerMaster CM 690 III Review
Up Close: Exterior Overview and Front
The ancestry of the 690 III can clearly be seen it's lines harking as they do back to the 690II and the original 690.  Gone are the pronounced shoulders though, replaced instead by a bevelled edge blending back to the case sides.  The highly reflective chrome strip is still in evidence and if anything it's slightly broader and more impressive.
CoolerMaster CM 690 III Review     CoolerMaster CM 690 III Review
The lineage of the 690 III can also be seen in the front elevation.  Large meshed areas, with the 5.25" bays barely distinguishable from the remainder of the meshed frontage.  The right hand side of the case is devoid of features having just a slight bulge to the side panel aiding rigidity and bestowing a few extra millimetres of cable management space.
Yes, we were also hoping for a window!  Thankfully the 690 III line up follows a similar patterns to that of it's predecors and it is available with a window.  We're guessing there will also be a lite version and a few different colours as the brand moves forward  In the meantime we have a non windowed, non bulged panel that has a large unfiltered ventilation area able to accommodate 2x120mm, 2x140mm 1x180mm or 1x200mm fans.  Granted that's not bad, but we'd still rather have had a window.  Did we mention we like windows???
The fine mesh that covers the front of the case is actually a series of vertical rectangles as oppesoed to the practically ubiquitous hex or circular mesh.  We've deliberately pulled focus here to help you see the structures behind the mesh and to give you an idea of how unobtrusive it is.
«Prev 1 2 3 4 5 6 7 8 9 Next»
16-09-2013, 05:32:45
Etlar
Miss a link :-DQuote
16-09-2013, 06:51:20
barnsley
Everytime I see this case it reminds me how much of a copy my enermax case is of this :l.
Anyway, good to see that its still a strong, solid performer.Quote
16-09-2013, 06:53:42
tinytomlogan
Originally Posted by Etlar View Post
Miss a link :-D
Easy doofus I was still putting it live.Quote
16-09-2013, 08:22:57
Saltire35
There is an optional window panel with no fan mount.
But whether this is just available in the US, time will tell.
eBuyer usually stock the panels as they are the only place in the UK I've found that stock them as they did with previous generations of the 690.
http://imagescdn.tweaktown.com/news/...the_690_ii.jpgQuote
16-09-2013, 08:26:07
jamesriley94
Sure about eBuyer?
Specialtech, OCUK and Scan, along with a fair few others stocked the CM690-II's windowed side panel, and did it for about £8.
I never saw eBuyer have them tbh, although I don't really use them anymore.Quote
