CoolerMaster CM 690 III Review
Up Close: Base, Rear, Roof and Reverse
Circular mesh ventilation runs practically the full length of the base of the cae, stopping only when it reaches the drive bay area.  Inlaid into this myriad of ventilation holes can be found mounts for a 120mm fan as well as a 2.5" drive.
CoolerMaster CM 690 III Review     CoolerMaster CM 690 III Review
Four rubber pad topped dimples provide a secure mount for the PSU, with an elongated non grommeted cut out enabling the cables to exit to the rear.
The 690 II has room for 7 expansion cards in addition to an eighth that sits vertically alongside for non mobo PCI devices such as fan and lighting controllers.  Up in the top corner we find a CoolerMaster branded 120mm fan on extract duty.
Looking now at the roof from the inside we can see that the rectangular mesh is supported by a plastic elongated honeycomb pattern mesh.  The mounting holes for 120mm and 240mm fans can also be seen, as well as those for the optional 200mm fan off-set into the metal of the chassis in the image below right.  The holes for the 240mm fans are elongated allowing for varying inter hole pitch on radiators, and although  there are 140mm holes, you're not going to be getting a 280 rad up here without a bit of modding.  But more of the water cooling options when we come to the build.
The reverse side of the 690 III is very well laid out  with 13 well distributed cable tie points, for example the row of tie points that run down the side of the vertical management holes and the sets of tie points around the slots for the rear mounted SSD.
At first the 19mm of space back here seems a little worrying, and it would be were it not for the bulged side panel which will bring the total space available up to a more than adequate 27mm
There's also plenty of room for managing what could be a multitude of power and SATA cables, should you choose to populate all the drive bays.
«Prev 1 2 3 4 5 6 7 8 9 Next»
16-09-2013, 05:32:45
Etlar
Miss a link :-DQuote
16-09-2013, 06:51:20
barnsley
Everytime I see this case it reminds me how much of a copy my enermax case is of this :l.
Anyway, good to see that its still a strong, solid performer.Quote
16-09-2013, 06:53:42
tinytomlogan
Originally Posted by Etlar View Post
Miss a link :-D
Easy doofus I was still putting it live.Quote
16-09-2013, 08:22:57
Saltire35
There is an optional window panel with no fan mount.
But whether this is just available in the US, time will tell.
eBuyer usually stock the panels as they are the only place in the UK I've found that stock them as they did with previous generations of the 690.
http://imagescdn.tweaktown.com/news/...the_690_ii.jpgQuote
16-09-2013, 08:26:07
jamesriley94
Sure about eBuyer?
Specialtech, OCUK and Scan, along with a fair few others stocked the CM690-II's windowed side panel, and did it for about £8.
I never saw eBuyer have them tbh, although I don't really use them anymore.Quote
