CoolerMaster CM 690 III Review
Up Close: Stripped
Up Close:  Stripped
Easily released plastic barbs allow the front of the case to be removed in one piece.  A large aperture for the 5.25" bays, beneath which lays the large 200mm fan.  We're not quite sure just how CoolerMaster have managed to squeeze this in here especially as the case itself is only 230mm wide and a good proportion of that is the bulge on the right hand side.  Should you decide you don't want the nice low speed low noise fan provided, you can always whip it out and replace it with your choice of either 2x120mm, 2x140mm or 1x180mm.
CoolerMaster CM 690 III Review     CoolerMaster CM 690 III Review
Both the 5.25" blanks and the main intake area are filtered.  On the downside though, whichever fans you go for if you want to clean the main filter you're first going to have to remove the front of the case
The 690 III comes with a multi language instruction booklet.  The images are clear and plentiful, but could do with being a little bigger.  Getting lost momentarily when we were looking for the English sentences it tickled us no end to find the Polish phrase "Jak podJak pod", which by all accounts means "How to install the Power supply"  How the Hell can a six word sentence, where none of the words are duplicated be translated into a three word sentence where there are essentially only two words???  Pod and Jak?  Still, it made us chuckle and reminded us that as Britons were are remarkably ignorant of other languages.
«Prev 1 2 3 4 5 6 7 8 9 Next»
16-09-2013, 05:32:45
Etlar
Miss a link :-DQuote
16-09-2013, 06:51:20
barnsley
Everytime I see this case it reminds me how much of a copy my enermax case is of this :l.
Anyway, good to see that its still a strong, solid performer.Quote
16-09-2013, 06:53:42
tinytomlogan
Originally Posted by Etlar View Post
Miss a link :-D
Easy doofus I was still putting it live.Quote
16-09-2013, 08:22:57
Saltire35
There is an optional window panel with no fan mount.
But whether this is just available in the US, time will tell.
eBuyer usually stock the panels as they are the only place in the UK I've found that stock them as they did with previous generations of the 690.
http://imagescdn.tweaktown.com/news/...the_690_ii.jpgQuote
16-09-2013, 08:26:07
jamesriley94
Sure about eBuyer?
Specialtech, OCUK and Scan, along with a fair few others stocked the CM690-II's windowed side panel, and did it for about £8.
I never saw eBuyer have them tbh, although I don't really use them anymore.Quote
