CoolerMaster HAF 932 Full Tower
With the recent review of the ATCS 840 and earlier review of the Centurion 590 it’s certainly fair to say that the name Cooler Master is no stranger to OC3D and the enthusiast scene as a whole. However, while the ATCS and the Centurion are at opposite ends of the pricing spectrum, today we are going to take a look at a case that sits nicely between them. This takes the form of the HAF (or High Air Flow) 932. HAF is a new line that Cooler Master have added to their full tower range. A range which already consists of some big names such as the Cosmos and Stacker series’. Hopefully with the wealth of experience and success that Cooler Master have had with those lines, we can expect some good things from the 932.
Lets see what Cooler Master have to say about the HAF 932 on their website:
With pure innovative strength, Cooler Master, the leader in enthusiast computer components, has unleashed yet another prevailing arsenal to compete in the full-tower chassis segment. Proud and robust in its appearance, the HAF 932 presents its sturdy sentinel housing and revolutionary High Air Flow structure to enhance and protect any hardware component that is worthy of the highest performance.
Available Color Black Dimension (W / H / D) (W)230 x (H)545 x (D)575 mm
(W)9.0 x (H)21.5 x (D)22.7 inch
Weight 13.2 kg
29.1 lbs
Material SECC, Plastic Motherboards Micro-ATX / ATX / E-ATX 5.25″ Drive Bay 6 (without the use of exposed 3.5 inch drive bay) 3.5″ Drive Bay 5 Hidden 1 Exposed (converted from one 5.25 inch drive bay) I/O Panel USB 2.0 x 4, IEEE1394a x1, eSATA x 1, Mic x 1, Audio x 1 Cooling System Front : 230x30mm red LED fan x 1 / 700 rpm / 19 dBA
Side: 230x200x30mm standard fan x 1 / 700 rpm / 19dBA
(support 120mm fan x 4)
Top: 230x200x30mm standard fan x 1 / 700 rpm / 19dBA
(support 120mm fan x 3 or 120mm x 1 + 230x30mm x 1)
Rear: 140x25mm standard fan x 1, 1200 R.P.M, 17dBA
(support 140mm fan)
Expansion Slots 7 Power Supply Standard ATX PS2 / EPS 12V (optional)
A sizable case with some nice features. The spec shows off some truly massive fans, hopefully meaning the case will live up to its name.
