Coolermaster Hyper 612S Review
Hyper Hyper!
Its been a long time since we have tested a Coolermaster heat sink here at OC3D, in fact I think the last one may well have been the V8 many moons ago. Hoping to build on the success of their competitively priced cooler, the Hyper 212S, they have now released its bigger brother the Hyper 612S. Ear marked as a cooler for those of us that enjoy a silent running PC the expectations are high.... Except the noise and temperature levels we want them low! Ok I'm rambling lets just move on before I dig a bigger hole.
- Optimized with wider fin gaps and resistance reduction cut-offs for low fan speed condition.
- Unconventional layout of the heat pipe direction: all 6 heat pipes can cross over the “hot zone” on most of the modern CPUs  for better cooling efficiency.
- Quick-snap fan bracket design for easier installation.
- Wide range PWM fan (600 – 2000 R.P.M.) provides versatile performance for full loading efficiency and for quiet idling.
CPU SocketIntel Socket:
LGA 1366 / 1156 / 1155 / 775 *
AMD Socket:
FM1 / AM3+ / AM3 / AM2+ / AM2
CPU SupportIntel:
Core™ i7 Extreme / Core™ i7 / Core™ i5 / Core™ i3 / Core™2 Extreme / Core™2 Quad / Core™2 Duo / Pentium / Celeron
Phenom™ II X4 / Phenom™ II X3 / Phenom™ II X2 / Phenom™ X4 / Phenom™ X3 / Athlon™ II X4 / Athlon™ II X3 / Athlon™ II X2 / Athlon™ X2 / Athlon™ / Sempron™
Dimension140 x 128 x 163 mm (5.5 x 5.5 x 6.4 inch)
Heat Sink MaterialCopper Base / 6 Heat Pipes / Aluminum Fins
Heat Sink Weight806g (1.78 lb)
Fan Dimension120 x 120 x 25 mm (4.7 x 4.7 x 1 inch)
Fan Speed600 - 2000 RPM (PWM) ± 10%
Fan Airflow24.9 - 82.9 CFM ± 10%
Fan Air Pressure0.3 - 2.7 mmH2O ± 10%
Bearing TypeLong Life Sleeve Bearing
Fan Life Expectancy40,000 hours
Fan Noise Level (dB-A)9 - 36 dBA
Fan Weight104g (0.23 lb)
Gigabyte UD3R V2
Intel i7 950 @ 4GHz 1.25v
Mushkin Radioactive 2000MHz
HIS 6850
Corsair Carbide 400R
Corsair AX750w
Video Review
We'll say from the off that we are hoping that the 612S follows what has made the Hyper range so popular, a low price. There is no confirmed UK price yet and all we can find out is that its expected to be $49.99 in the USA, so we would like to think this will mean it will come in at a maximum of £40 when released in the UK.
When looking at the graphs the 612S is actually the worst performing cooler on that chart, and unless they charge £30 for it then it wont be the cheapest either. It is up there with the best of them when it comes to silence, because it is near as dammit silent. To the point there is no air noise at all, you can only just about hear a faint hum from the fan motor itself. Its so quiet it actually made the mechanical hard drive in the test rig sound loud! Having the option of fitting a second fan may help the performance of the unit and the brackets are included, but as the second fan wasn't an out of the box option we did not add one for the review.
The mount isn't as sophisticated as the 2 stage mounts from the likes of Noctua and Prolimatech but it's much easier to mount than a Scythe cooler. Having the mounting threads fixed to the cooler itself and having them push through to the back of the motherboard where you then bolt it all in place is actually really easy to do, easy for a single handy man but even 2 complete idiots should be able to get this thing mounted somewhere near correctly. If you have gone red you know that means you!
The Hyper 612S is a great looking cooler although performance isn't as good as we were expecting for the size and build quality of the unit. We have a feeling this is down to the fan and the fact we believe Coolermaster have obviously aimed this at near silence rather than performance. I do believe though that a carefully selected fan could unleash much better performance from this cooler without adding much if any extra noise to it. I don't how ever think that it will be worth spending any extra money on should it come in at £35-£40. If it was my money and I was thinking about adapting this cooler I would just spend more money on a cooler that performs better out of the box. Even the Thermolab Trinity that sells for just £30 managed to be as quiet as this and still perform better.
So to recap its a good looking and good performing cooler, but its not great. Its success when hitting the stores will hinge completely on how much the final price is. If it comes in at below £40 we would recommend it being on your list of possible purchases and based on its near silent operation we would award it the OC3D Silence award.
[12/09/2011] Coolermaster have now informed us the price at launch has been dropped to around £35 GBP
 We would like to thank Coolermaster for the sample we tested today, you can discuss your thoughts in the forums.
«Prev 1 Next»
09-09-2011, 04:07:49
We take a look at the latest heatsink from Coolermaster the Hyper 612S. Can it build on the success of its little brother the 212?
Continue Reading
09-09-2011, 04:15:40
Awesome Review Tom. It is an OK cooler for the price and the only thing going for it is the silence factor.
09-09-2011, 07:11:09
I would only get this if i was building a really quiet pc. It's a good review, it's so quiet at 12v
