Corsair Carbide Spec 04 Review
It’s been while since we’ve reviewed a budget case, so with this in mind we thought we’d take a look at the brand new Spec 04 from Corsair.  At under £50 it’s certainly inexpensive.  However, it’ll still need to cut the mustard if we’re to rate it, and especially if we’re to award it our coveted “Value” award.  First impressions are that it’s a very light case,with a quick glance at the specs telling us it tips the scales at just 4.2kg.  Let’s hope that Corsair haven’t cut back too much and made a case with the structural integrity of a crisp packet.  For more detail let’s have a look at that all important Technical Specification
Dimensions  492x201x433mm LxWxH)
Material  Steel, Acrylic
Weight  4.2kg
Motherboard  ATX, M-ATX, M-ITX
Front I/O  Power/Reset, 1xUSB2.0, 1xUSB3.0, Audio
Expansion Slots  7
3.5″  3
2.5″  2
Air Cooling
 Front:  2×120/140mm (1×120 included)
 Roof:  2x120mm
 Rear:  1x120mm
Water Cooling
 Front:  1×120/140mm
 Roof:   None
 Rear:   1x120mm
Max CPU Cooler Height  150mm
Max GPU Length  370mm
Max PSU Length  225mm
Â
