Corsair Graphite 230T Review
We're not sure whether you can use the term "series" with regards to PC cases if there's only one case in the "series".  You see up to now the 600T has been more than a little lonely being as it was the only member of the Corsair Graphite series.  We say was as it now has some company in the form of the new Graphite 230T.  A mid tower case aimed quite squarely at gamers the 230T has striking lines, and if you opt for the Orange featured in the review sample quite striking colours too.  Should you fancy something a little more subtle you could always opt for the more classic Black or slightly avant-garde Grey.  Each of the cases comes complete with 3x120mm fans, the front two of which are LED units intended to compliment the tone of the case.
Dimensions550x210x440mm LxWxH
Weight6.16kg
2.5" bays4
3.5" bays4
5.25" bays3
Cooling
Front 2x120 LED included
Rear 1x120 included
Roof 2x120 or 2x140 Optional
Base 1x120 or 1x140 Optional
CompatibilityATX, mATX, Mini ITX
Expansion slots7
Max CPU Cooler Height160mm
Max GPU Length
430mm Top slots
320mm Lower slots
«Prev 1 2 3 4 5 6 7 8 Next»
15-10-2013, 06:10:16
Excalabur50
But does it come in WHITE?Quote
15-10-2013, 06:40:10
chrismjurd
is it just me or is that orange totally rad!Quote
15-10-2013, 06:49:23
G-Dubs
Nope not just you, we also think it rocks Quote
15-10-2013, 10:05:50
Nerdfighter
Damn, it does look pretty sexy. Personally would of preferred better quality dust-filters and some grommets on the cable routing holes, in exchange for a slightly higher price tag. I hope Corsair releases a mid-tower in the 80 - 100 quid range as well, even though that section is pretty filled already with other cases.Quote
16-10-2013, 15:42:01
qhfreddy
Pretty good looking case, just looks a tad flashy next to the 600T though. Still, a nice change from the rather unimpressive looks the other Corsair cases have.Quote
