Corsair Graphite 230T Review
Up Close: Rear of Motherboard
There might only be seven cable tie points, but boy are they are well distributed.  In the ideal world we would prefer the ones nearest to the vertical management holes to be off set to one side but as Corsair have actually  recessed this channel, giving greater depth we can hardly be critical of their choice of cable tie point location.  There's also a nice clear line of tie points going across the bottom and working their way up the right hand side.  Ok, so we favour tucking the 8 pin CPU power cable into the recess at the side, but the tie points are there if you need them.
Corsair Graphite 230T Review     Corsair Graphite 230T Review
It's actually quite spacious back here, with a good deep trough running along the base and along the top of the case.  Perfect for stashing all those unwanted cables
The feeling of space isn't that well supported by the metrics.  The majority of the case having just 15mm of space to work in.  Thankfully Corsair have actually recessed the route the majority of the main cables will take to a very agreeable 23mm of depth for cable management
«Prev 1 2 3 4 5 6 7 8 Next»
15-10-2013, 05:59:26
tinytomlogan
http://www.overclock3d.net/gfx/artic...065038434l.jpg
The 230T is a brand new addition to the Corsair fleet of Graphite cases. A Mid tower aimed at gamers, lets see how it sails
Continue ReadingQuote
15-10-2013, 06:10:16
Excalabur50
But does it come in WHITE?Quote
15-10-2013, 06:40:10
chrismjurd
is it just me or is that orange totally rad!Quote
