Corsair H60 AIO Review
Unless you've had your head in the sand of late you'll know that Corsair have not only moved away from traditional CPU air cooling, but have also been refreshing their "Hydro" Series of AIO water coolers.  We've already taken a look at a cross section of the range back in January in the "Battle of the AIOs".  What we didn't do back then was have a look at what could be thought of as Corsair's Entry level AIO water cooler.  With the H60 costing just £60 it's price places it not only into the more affordable end of AIO water coolers but also into the same sort of territory as some of the larger Mid range traditional air cooling units.  However  unlike the larger air coolers the H60s diminutive size means that you're not going to have to worry quite so much about case compatibility and RAM encroachment.  Indeed, with SFF and HTPC becoming more popular the H60 potentially offers the ability to cool an overclocked chip in a case where the fitting of a large tower just isn't an option.
However even if you haven't had your head in the sand it's not barn door obvious from the naming of the H60 that this unit replaces the older outgoing H60, as the two share the same name.  Gentlemen, we give you the H60....Which replaces the H60...Eh?  Fortunate then that retailers have taken things into their own hands are referring to this unit as the V2.  Under the skin they are quite different, with the new unit sporting  a revised block and pump, along with rubberised as opposed to corrugated tubing, and even a new fan for the Radiator.
Technical Specification.
Radiator Dimensions120x152x27mm
Fan Dimensions 120x120x25mm
Fan Speed 2000RPM +/- 10%
Fan Noise 30.85dBA
 Fan Airflow 54CF/M
Fan Static Pressure 2.36mm/h2O
Contact Plate Material Copper
Radiator Material Aluminium
 Tubing Low Permeability
 Intel Socket LGA 775, 1155, 1156 1366, 2011,
 AMD Socket AM2, AM3, FM1, FM2
«Prev 1 2 3 4 5 6 Next»
28-03-2013, 05:59:47
tinytomlogan
The second generation H60 AIO watercooler from Corsair offers entry level water cooling at price similar to some midrange Air coolers. But is it any good?
http://www.overclock3d.net/gfx/artic...141945926l.jpg
Continue ReadingQuote
28-03-2013, 06:14:05
FTLN
Been waitin for this one, might have to rma my original to get one of these back Quote
28-03-2013, 06:30:38
Lystfiskern
Link missing?
EDIT. Refreshed the page and there it was - BOOMQuote
28-03-2013, 06:41:12
tinytomlogan
Originally Posted by Lystfiskern View Post
Link missing?
I need the thread here before I can put the review live dude. Just need to be patient Quote
28-03-2013, 07:04:03
Blackbeard
You ain't seen me, right?...
Quote
28-03-2013, 07:10:59
Lystfiskern
Aaah! Ok, I just happened to open thread just before you provided the link then.
Thx for a clean honest review as we have come to expect from OC3D.
1 thing - I really would mind the graphs being sorted by best performance cooler (delta -load) if at all possible?
Although its not to much of a hassle comparing with the other logical contenders so not that big of a deal if rearranging graphs is a large job.Quote
28-03-2013, 07:14:06
tinytomlogan
We need a new graph program to sort them, our current one is old and needs to be done manually Quote
28-03-2013, 07:18:55
FTLN
Well I been living with clunk clunk brrrrrr of the pump for a while so I can jsutify the rma
Dont even let me get on to the subject of the flock of birds that live in my ax650 Quote
28-03-2013, 08:02:37
Lystfiskern
I hear ya - would receiving a simple excel-macro with how-to instructions do do the job? If your not on to a spesific program already maybe open a thread for suggestions and possible help on the subject?Quote
28-03-2013, 08:23:17
tinytomlogan
No mate it needs to look nice and we dont want our to look the same as every other excel user.Quote
28-03-2013, 09:02:31
kenny'sghost
and with that I'm back in 2 minds.. Air cooler or this..
I want a H60.. well I want a H100 but my budget does not allow it..even the H60 is abit over budget I want to spend on a cooler..Quote
28-03-2013, 09:09:14
Lystfiskern
Point taken. Will let u know if I come across possible options/sdolutions.Quote
28-03-2013, 12:01:26
alienware
I'm running one of these. Well, I'm running the Coolit Eco II but it's basically identical it just doesn't have any branding. Mine uses the older type flexi hose that the old H60 used IIRC.
A good cooler. I dialed in the fan using my Alienware control board and it's very quiet and does an admirable job on my Xeon (I6, basically).
My load temps are usually under 50c and sometimes just over but more than controlled enough.
This cooler is ideal for non K CPUs IMO. You can really down the fan speeds and dial it in to be super quiet
Another fine review chaps, thanks !Quote
02-04-2013, 03:25:27
Dexo
Overall a great cooler, stock fan is a bit noisy, but I replaced them with 2 Corsair quiet series and now the pump on full is loder
The pipes for me seemed a bit stiff and it was a bit of struggle to bend cooling unit into proper angle. I'm still not sure if the unit is properly covering cpu, temps are ok though- 3570k @ 4.4 ghz not a swet Quote
04-04-2013, 04:08:07
Vlada011
CORSAIR always make best looking pump/block part.
And for H60, H100, H100i.Quote
