Corsair H70 Review
Published: 10th August 2010 | Source: Corsair | Price: £92.68 |
Ahhh bigger. We like bigger. No matter what it is, when it comes to PC hardware, bigger is nearly universally better. Bigger hard-drives give more space. Bigger RAM gives improved application performance. Bigger heatsinks gives better cooling.
The same is true of radiators. A bigger radiator in your house produces more heat. A bigger radiator in your water-cooling loop gives lower temperatures.
Of course there are some limitations to size. You'd never fit a Noctua NHD14 into a HTPC case for example.
As you can probably tell from the cooling theme of the introduction, todays review is of something that is bigger, and therefore hopefully improved, version of a CPU Cooler we've previously tested here at OC3D.
When we tested the Corsair H50 we found it had a great mounting system and reasonable performance for a self-contained CPU water-cooler. However it just didn't have either the rad-size or pricing to be a sensible alternative to a high-end heat-pipe tower style air cooler.
Corsair have have been busy beavering away in their labs and have produced the H70. So before we take a look at this big brother to the H50, let's grab the features off of the Corsair website.
Features
- Pre-filled, closed-loop system is easy to install
- Copper CPU cooling plate for maximum cooling performance
- Integrated pump and reservoir is sealed for zero maintenance and improved leakage protection
- Large, double-thick 120mm radiator for outstanding heat dissipation
- High-performance, twin 120mm fans offer outrageous airflow in push-pull configuration
- Included step-down adapters let you customize your fan speed for low noise or high performance.
| Model | CWCH70 |
| Cold Plate Material | Copper |
| Fan Specs | 2 x 120mm, selectable 2000RPM or 1600RPM |
| Radiator Material | Aluminum |
| Tubing | Low-permeability for near-zero evaporation |
The main improvements are an improved CPU block/pump and a much larger radiator. As well as the inclusion of two fans in a push-pull setup. Certainly on paper it has everything that the H50 needed. So let's take a look.
Looks like it will be another cult-esque success tbh, ideal for people who want water cooling for its cool factor (*groan*) but don't want to get into something that may leak and needs constant attention.
Hopefully one day (cough cough hint hint) Corsair will consider making something similar for GPUs. I would rush out to get something like this that fitted my 5770s.
I do have a criticism with this unit though. The hoses.
With my specific case (the Alienware Predator 2) the unit really needs to be in the front. The hoses simply are not long enough. Corsair know this too as many people have a similar issue to myself. Maybe in the future they can make two models. One for front mounting and one for rear.
Sounds like you were suffering a bit with man-flu tho
The radiator seems massive and it sounded pretty loud when you put the camera near the test station.
For nearly £100 it seems pretty expensive
I have seen the H50 for £50-60 so would guess a lot of people would just buy that instead.
I'm thinking of building a custom watercooled rig at the moment so seeing this review has made me think a little more (in favour of getting a proper custom loop)
Also the H50/H70 don't seem to have the ability to compete with any proper watercooling setups, if anything they seem to be a replacement for air coolers.
so the dh14 is still the better AIR cooler?
o well
EDIT- i have just read another review and when overclocked to 4.1 (980x) the h70 does beat the dh14 at full load by 8c,not quite shure how impartial the review was but still
yer your right i ught i saw it on another review that it beat it by 3c (h70 at 12v push/pull) but it wasent lol o well EDIT- i have just read another review and when overclocked to 4.1 (980x) the h70 does beat the dh14 at full load by 8c,not quite shure how impartial the review was but still |
Nice one Tom. Thanks for the review ! Looks like it will be another cult-esque success tbh, ideal for people who want water cooling for its cool factor (*groan*) but don't want to get into something that may leak and needs constant attention. Hopefully one day (cough cough hint hint) Corsair will consider making something similar for GPUs. I would rush out to get something like this that fitted my 5770s. I do have a criticism with this unit though. The hoses. With my specific case (the Alienware Predator 2) the unit really needs to be in the front. The hoses simply are not long enough. Corsair know this too as many people have a similar issue to myself. Maybe in the future they can make two models. One for front mounting and one for rear. |
Just playing devils advocate here and i may have missed something but your review seems to have been tested on an open system ( unless someone actually bought an antec skeleton not your normal user setup ) so a good air cooler should win out . Put the coolers in a case ( and in the case of the h70 setup as per Corsair as an intake ) and the results would be very different , another review even had the 980x ref cooler better than the dh-14 when tested in a case . |
Well they at least bothered to actually put the coolers into a case , they also stated that the dh-14 was not mounted in what would be its best position due to its size - well you can house a family of 5 in that things footprint - , lastly the 980x heatsink is a fair bit better than the normal i7 jobby . |
I have the NH-D14 in my own rig IN a case and it makes all of 1-2c difference. taking that in to account combined with the time and ease of using a test bench means we will continue to test this way. All of our readers are bright enough to make their own conclusions on in case temps if they wish.
I might add a LARGE selection of our members and readers have bought the NH-D14 and all also report within 1-2c the temps I stated in the review.
So, must be fairly accurate eh
Andy - 0
The only heatsink it makes any difference on would be the H50/70 and thats why Corsair want it tested differently. I would suggest they want it tested this way as it is the recommended installation method I have the NH-D14 in my own rig IN a case and it makes all of 1-2c difference. taking that in to account combined with the time and ease of using a test bench means we will continue to test this way. All of our readers are bright enough to make their own conclusions on in case temps if they wish. Viewers of this site may be intelligent but are'nt mind readers , you don't specify either in the typed review or the video that it is an open test , also although you use the stock fans with the H70 you dont specify the type and number of fans fitted to the dh-14 which brings it all down to guesswork , feel free to check hexus or hardware canucks reviews that list in detail exactly what they are testing with . I might add a LARGE selection of our members and readers have bought the NH-D14 and all also report within 1-2c the temps I stated in the review. I had an prolimatech a while ago and found that even the H50 ( push/pull ) outperforms it when you factor in a couple of sli'd toasters ( average of 9-12 degrees cooler on a 930 after an evening of BC2 ) I would add that i am neither a fan or hater of either the d14 or the h70 and have enjoyed a lot of the reviews from here over the last year or so but the type of person who buys these coolers will generally be running high end kit which generates heat and therefore would like to see these tested in real world environments So, must be fairly accurate eh My machine is based on a i7-930 ( 3.4 mildly o/c'd )yet in a closed case with its back against the wall i idle at ~ 33 and running prime overnight will only hit just over 60 ( ambient ~ 18-20 ) , not really in line with your results |
And we test all sinks with the fans that they come with unless specified. Funny how you are the only one with any kind of problem, everyone else knows
and
Tom - 2
Andy - 0
You need to remove your reply fromt the quote above^^^ And we test all sinks with the fans that they come with unless specified. Funny how you are the only one with any kind of problem, everyone else knows |
So NOW you tell me you test with fans as the units come ( why make a song and dance about installing h70 as intake then when that is the recommeded install method ) , now please show me where in either your typed review or in your video where you state that ( back to mindreading/guessing again ) .
I have no problem with any of the above but you still seem either unable or unwilling to note that if you have 1 , 2 or more graphics cards in your machine - not normally more than a couple of inches away from the cpu - then a heatpipe cooler will be more affected than any of the rad type coolers from corsair/coolit/asetek ( running them as intake ) due to them pulling in cooler air from outside the case , again not something you'll notice as much running on an open system
Was looking around and found some pics of the H50 block
Also didn't even realise this:
Radiator Material: Aluminum
Continue Reading
